Kensington SoleMate Plus Footrest
Quicklinx: 56CPWS00 Mfr#: 56146
Type: Footrest
Hurry, only 1 left in stock!
£46.15 ex VAT
£55.38 inc VAT
Footrests keep legs elevated for improved posture and circulation while you work at a desk and help reduce pressure on the lower back. They are easily adjustable for extra comfort, while there is a range of specifications available to suit individual requirements.
  • SmartFit system
    Allows you to dial in your ideal setting, with adjustable height and tilt options that you can match to your personal comfort color using the hand chart that's included with your foot rest.
  • Promotes better posture
    Work in better comfort throughout the day as the foot rest helps put you in better, stress-reducing posture while you're sitting, which relieves pressure on your feet, back and legs.
  • Foot pedal adjustment
    With a simple push of your foot on the pedal, you can make adjustments to the foot rest without having to get out of your chair and interrupting your productivity (3.5"-5" in height or 30 degrees in tilt).
  • Non-skid surface
    Large area covered in rubber provides great stability for your feet while you're sitting so you don't need to worry about them slipping off the foot rest.
Kensington SoleMate Plus - foot-rest
Foot-rest
Grey
45 cm x 35 cm x 9 cm
3.04 kg
0° to 20° adjustable angle, non-slip footboard, textured control surface, SmartFit
Foot-rest
45 cm
35 cm
9 cm
Adjustable Height
8.89-12.7 cm
3.04 kg
55.9 cm x 36.4 cm x 9.4 cm / 3.41 kg
Grey
Limited warranty: - 1 year
Resources
The following resources are available for the Kensington SoleMate Plus Footrest
Type: Footrest
Brand: Kensington
