Kensington SmartFit Sit Stand Desk
Quicklinx: G8QLWS00 Mfr#: K52804WW
£362.07 ex VAT
£434.48 inc VAT
For more than 35 years, innovation, quality and trust have made Kensington The Professionals' Choice in desktop productivity solutions. Incorporating Kensington's patented technology to ensure proper fit, the SmartFit Sit/Stand Desk provides an efficient and safe way to convert your desk into a healthy sit-stand workstation using a convenient desk-on-desk design. Strong and stable at any height, while using a pneumatic lift to effortlessly raise and lower your workspace within a space-saving footprint, the Kensington SmartFit Sit/Stand Desk delivers optimal productivity and ergonomic support.
  • Fully assembled
    Simply remove the desk from the box and place it on your standard work surface to begin enjoying the benefits of being able to sit or stand while you work.
  • Professional two-tier structure
    Increase your productivity and comfort with the wide desk surface that provides plenty of room for a single or dual monitor set-up, documents and other desktop accessories, an integrated deck for the keyboard and mouse and ergonomically designed beveled edges to help reduce contact stress.
  • SmartFit system
    Developed using U.S. Army research that found a direct correlation between the size of hand and body measurements, the SmartFit System demystifies ergonomics and gives you the confidence that you are using the desk in the correct position to help prevent injury and increase comfort.
  • Pneumatic lift with tension adjustment system
    Within seconds you can easily transition up to 35 lbs (15.9 kg) of weight between sitting and standing positions with a light squeeze of the spring paddle. The gas spring makes the transitions smooth and effortless.
  • Space-saving design
    Fitting on a desk area as shallow as 21 in (533 mm), and great for cubicles and corner workspaces, the desk moves straight up and down within its own footprint - never protruding beyond the desktop surface.
  • Height extension
    Providing an excellent range for people of all heights, the desk raises up to 22.8 in (580 mm) to accommodate taller individuals with the right height for proper use.
  • Proper weight capacity
    Supporting the weight of most dual monitor set-ups with added peripherals, such as docking stations and storage drives, the main desk surface holds up to 30 lbs (13.6 kg), and the integrated keyboard and mouse deck supports an additional 5 lbs (2.3 kg).
  • Cable management system
    Simply route the monitor and accessory cables through the provided cable hooks to keep your desk tidy and uncluttered.
Kensington SmartFit Sit/Stand Desk - notebook stand
Notebook stand
90 cm x 66.6 cm
Pneumatic lift, SmartFit, integrated cable management, two-tier structure, Zero Footprint Mounting
Notebook stand
90 cm
66.6 cm
Adjustable Height
16-58 cm
Weight Limit
15.9 kg
Brand: Kensington
