One size doesn't fit all. When it comes to comfort, fit is everything.
Complying with ergonomic standards doesnt have to be a pain. The Kensington SmartFit system eliminates the complication, confusion and high cost of giving your employees safe, comfortable, ergonomic workstations. Years of research from the US Army revealed a direct correlation between hand size and body measurements. The result is a simple colour-coding system that allows users to adjust for the perfect fit in seconds, every time, leaving you to deal with more important projects.
SmartFit demystifies ergonomics for individuals making it easy to install and customise their workspace accessories to their ergonomic comfort requirements.
Every SmartFit product includes a hand chart in the box. This indicates the specific SmartFit colour setting that will deliver optimum ergonomic comfort for the user.
A small investment in workplace ergonomics can generate significant rewards in productivity by reducing fatigue.
- Kensington Flat Panel Monitor Stand - stand
- Product Type
- Stand
- 58 cm x 30 cm x 10 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- Up to 21"
- 58 cm
- 30 cm
- 10 cm
AV Furniture
- Stand
- Recommended Use
- Flat panel
- Shelf Qty
- 3
- Up to 21"
- Adjustable height
Resources
The following resources are available for the Kensington Monitor Stand with Adjustable Shelves - Graphite
Customer reviews
Write a review for the Kensington Monitor Stand with Adjustable Shelves - Graphite here!
An effective, tidy use of desk space
Reviewed by K.J Boyle. Review Posted 13/05/2006
I was quite surprised to find that this was made of plastic (appears metallic in the picture...but then so does my TFT monitor!). That said it is an extremely strong and robust design. The main stand easily fits my 19" monitor on top and the box states it is suitable for 21" monitors, weights up to 35lbs...would have been nice to have this information on the weblink (can you add this please DABS). The main stand can also be raised to allow 80 mm gap for keyboard (plenty of space here too) or 50 mm if you prefer. The side panels can be position in three ways (basically as per photo and then at varying levels of overlap with the main stand. Mine are big and strong enough to hold my speakers, so good stuff there. Easy to set up (less than 5 mins) and does the job. Good price, recommended. It is bigger than I expected so check dimensions if unsure.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
