Kensington Spin2 Monitor Stand - Black
Quicklinx: CRKLWS00 Mfr#: K52787WW
Accessory Type: Stand
Hurry, only 3 left in stock!
£32.45 ex VAT
£38.94 inc VAT
Let the ergonomics innovator with long years of expertise maximize your desktop space with this professional monitor stand. The patented, spinning multi-compartment storage area underneath the platform provides easy access to your most-used desktop tools and accessories. Measure, adjust and fit yourself with Kensingtons patented SmartFit System so you can customize your monitor height using the color-coded personal comfort system.
SmartFit® System
Allows you to dial in your ideal setting, with adjustable height options that you can match to your personal comfort color using the hand chart that’s included with your monitor stand.
360-Degree Spinning Carousel
Patented multi-compartment area reduces desktop clutter by giving you rotating individual sections for quick and easy access to your desktop supplies like paper clips, sticky notes, staples, pens, and so much more.
Reduce Eye/Neck Strain
By setting your monitor at the proper height that’s in line with your eyes, you can lower the chances you will suffer from aches and pain after spending long hours on the computer day after day.
Small Footprint
Conserves your desktop space and offers an elegant look while providing a sturdy design that can hold a widescreen monitor up to 40 pounds
Kensington SmartFit Spin2 stand - for Monitor - black
Stand
Rotation
360°
Adjustments
Recommended Use
Monitor
Max Load Weight
18.1 kg
3-year warranty
AV Furniture
Stand
Recommended Use
Monitor
Rotation
360°
Adjustments
Max Load Weight
18.1 kg
3-year warranty
Brand: Kensington
