Kensington SmartFit Extended Monitor Arm
Quicklinx: CRK8WS00 Mfr#: K60904US
One size doesn't fit all. When it comes to comfort, fit is everything.
Complying with ergonomic standards doesnt have to be a pain. The Kensington SmartFit system eliminates the complication, confusion and high cost of giving your employees safe, comfortable, ergonomic workstations. Years of research from the US Army revealed a direct correlation between hand size and body measurements. The result is a simple colour-coding system that allows users to adjust for the perfect fit in seconds, every time, leaving you to deal with more important projects.
SmartFit demystifies ergonomics for individuals making it easy to install and customise their workspace accessories to their ergonomic comfort requirements.
Every SmartFit product includes a hand chart in the box. This indicates the specific SmartFit colour setting that will deliver optimum ergonomic comfort for the user.
A small investment in workplace ergonomics can generate significant rewards in productivity by reducing fatigue, chronic injuries, absenteeism and even legal costs.chronic injuries, absenteeism and even legal costs.
Kensington Column Mount Extended Monitor Arm with SmartFit System - monitor arm
Monitor arm
United States
Monitor arm
United States
