Juice Triple Juice - 3.4Amp 3-Port Mains Adapter
Quicklinx: FKPTWS00 Mfr#: MAINS-3PORT-3.4A-WHT
Treble the power for your gadgets!
You will wonder how you ever managed without the Triple Juice!
This charging adaptor has multiple USB ports and can charge three devices at once from a single mains socket. The first port is 2.4 Amp of output and is specially designed to charge your tablets and smart devices quickly. The remaining ports are 1 Amp and can charge all other devices.
Key Features
Powerful three port charging adaptor to charge multiple devices at once.
1 x high speed USB port
2 x standard speed USB ports
Will charge all devices via your existing USB charging cables (not included).
Charging indicator light.
Designed in the UK.
Box Contains
Triple Juice mains charger (USB Cable not included)
Juice Triple power adapter - 3 x USB Type A
Power adapter
4 cm x 9 cm x 6 cm
181 g
White
Output Connector Type
Total 3: 3 x USB Type A
Max Electric Current
3.4 A
Power Device Details
- 4 pin USB Type A - 2.4 A , 2 x - 4 pin USB Type A - 1 A
Power adapter
Tablet
4 cm
9 cm
6 cm
181 g
Enclosure Colour
White
Output connectors
Total 3: 3 x 4 pin USB Type A
3.4 A
4 pin USB Type A - 2.4 A , 2 x 4 pin USB Type A - 1 A
Charging LED indication
