Juice 3 Portable power bank with 10,000 mAh battery capacity.
Portable charger for mobile charges an average smartphone from 0-50% in only fifty minutes and 3 charges of an average smartphone.
2. 4 Amp max output to charge mobiles
10000mAh/37Wh portable power bank
Charge 2 devices at once
USB-A and USB Type-C ports
Digital display to check remaining energy levels
Spec
Input 1: Micro USB DC5V/2A.
Input 2: Type C DC5V/2A.
Output 1: USB A DC 5V/2. 1A (max).
Output 2: TYPE C DC 5V/2. 4A (max).
Total Output: DC 5V/2. 4A (max).
CE certified.
Colour: Black
- Juice 3 power bank - USB, 24 pin USB-C
- Product Type
- Power bank
- 6 cm x 3 cm x 9 cm
- 195 g
- Black
- Output Connector Type
- USB, 24 pin USB-C
- Voltage Required
- DC 5 V
- Voltage Provided
- DC 5 V
- Max Electric Current
- 2.4 A
- Battery
- 10000 mAh - 37 Wh
- Power Device Details
- - 4 pin USB Type A - 5 V - 2.1 A , - 24 pin USB-C - 5 V - 2.4 A
- Product Type
- Power bank
- Designed For
- Mobile phone
- 6 cm
- 3 cm
- 9 cm
- 195 g
- Enclosure Colour
- Black
- Voltage Required
- DC 5 V
- Input Connectors
- 5 pin Micro-USB Type B, 24 pin USB-C
- Input Connectors Qty
- 2
- Voltage Provided
- DC 5 V
- Output connectors
- 4 pin USB Type A, 24 pin USB-C
- 2.4 A
- 4 pin USB Type A - 5 V - 2.1 A , 24 pin USB-C - 5 V - 2.4 A
- Capacity
- 10000 mAh - 37 Wh
- Charged, battery level indicator
