The Juice 5 Charge Power Bank with 15,000mAh (Five Full Charges) battery capacity. With the Juice 5, we head into festival territory. If you are away for 4-5 days camping, or anywhere away from mains power, the Juice 5 Charge Power Bank has you and your pals covered. With 5 full charges you don't need to stress about running out of power over a longer period.
Features:
Holds Five Full Charges Charge Two Devices at Once (USB Type-And and USB Type-C Outputs) 0-50% Charge in 50 Minutes Compact / Lightweight Design Digital Battery Level Display
- Juice 5 power adapter - USB, 24 pin USB-C
- Product Type
- Power adapter
- 6 cm x 3 cm x 14 cm
- 313 g
- Black
- Output Connector Type
- Total 2: USB, 24 pin USB-C
- Voltage Required
- 5 V
- Voltage Provided
- DC 5 V
- Max Electric Current
- 2.4 A
- Battery
- 15000 mAh - 55.5 Wh
- Product Type
- Power adapter
- Designed For
- Tablet, mobile phone
- 6 cm
- 3 cm
- 14 cm
- 313 g
- Enclosure Colour
- Black
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type A, 24 pin USB-C
- Input Connectors Qty
- 2
- Voltage Provided
- DC 5 V
- Output connectors
- Total 2: 4 pin USB Type A, 24 pin USB-C
- 2.4 A
- Battery status display
- Capacity
