The Juice 3 Charge Power Bank with 10,000mAh (Three Full Charges) battery capacity. The perfect accessory for a day or two off the grid – if you know you'll be without mains power for your little staycation or special trip away this year, don't forget to pack the Juice 3 Charge Power Bank to make sure all your devices are powered up. Don't want to miss the perfect photo op!
The Juice 3 charges an average smartphone from 0-50% battery in only fifty minutes and holds three complete charges of an average smartphone. With a digital battery level display to check remaining energy levels – you should never get caught out!
Oh, and if you're feeling generous the Juice 3 Charge Power Bank allows you to charge two devices at once. So, if you have a friend in need you can always give them a quick power boost whilst you both charge up.
All Juice Power Banks come with a 12month warranty.
Specifications:
Input 1: Micro USB DC5V/2A
Input 2: Type C DC5V/2A
Output 1: USB A DC 5V/2. 1Amp (max)
Output 2: TYPE C DC 5V/2. 4Amp (max)
Total Output: DC 5V/2. 4Amp (max)
CE Certified
Dimensions
W x D x H (cm): 9.3 x 6 x 2.5
- Juice 3 power bank - USB, USB-C
- Product Type
- Power bank
- 6 cm x 3 cm x 9 cm
- 195 g
- Black
- Output Connector Type
- USB, USB-C
- Voltage Required
- DC 5 V
- Voltage Provided
- DC 5 V
- Max Electric Current
- 2.4 A
- Battery
- 10000 mAh - 37 Wh
- Power Device Details
- - 4 pin USB Type A - 5 V - 2.1 A , - 24 pin USB-C - 5 V - 2.4 A
- Product Type
- Power bank
- Designed For
- Mobile phone
- 6 cm
- 3 cm
- 9 cm
- 195 g
- Enclosure Colour
- Black
- Voltage Required
- DC 5 V
- Input Connectors
- 5 pin Micro-USB Type B, 24 pin USB-C
- Input Connectors Qty
- 2
- Voltage Provided
- DC 5 V
- Output connectors
- 4 pin USB Type A, 24 pin USB-C
- 2.4 A
- 4 pin USB Type A - 5 V - 2.1 A , 24 pin USB-C - 5 V - 2.4 A
- Capacity
- 10000 mAh - 37 Wh
- Charged, battery level indicator
