The JBL Xtreme 2 features a bold design coupled with several other enhancements to further the success of the JBL Xtreme. Enhanced sound quality, larger bass, makes the Xtreme 2 a powerful, and long-lasting, musical companion. With the addition of the 3D bass radiators and upgraded drivers, users can not only hear powerful, room-filling sound, but physically see and feel it.
The Xtreme 2 features JBL Connect+, allowing users to wirelessly link one-hundred or more Connect+-enabled speakers, amplifying the experience through a connected ecosystem. The Bluetooth streaming capability allows up to 2 users to connect to the same speaker, so everyone gets the chance to hear their favorite songs.
Integrated hooks, a durable metal base, and a bottle opener added to the carrying strap make the speaker a fun and easy-to-transport addition, as well as a perfect audio solution for any home. Whether in the living room, poolside, or tailgating for the big game, the JBL Xtreme 2 brings bold sound wherever it goes.
The JBL Xtreme 2 incorporates a noise and echo canceling speakerphone, allowing it to be used to make crystal clear calls in any environment when paired with a smartphone. It also features a USB charging port, allowing users to charge any smartphone or tablet, so the party never has to stop.
Wireless Bluetooth streaming
Wirelessly connect up to 2 smartphones or tablets, giving everyone the chance to play their favorite playlist. -
IPX7 waterproof
Don't let weather conditions stop you from partying on; this speaker can be submerged in water with a waterproof design. -
JBL Connect+
Has the power to connect up to 100 JBL Connect+-enabled speakers together. -
Lifestyle material
Integrated metal hooks and durable fabric material allows speakers to withstand all of life's adventures. -
JBL bass radiator
See and hear improved acoustic and bass quality through updated drivers and passive radiators. -
Speakerphone
Equipped with noise and echo canceling speakerphones so all calls are crystal clear.
- JBL Xtreme 2 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Waterproof
- Speaker Type
- Active
- Continuous Power
- 40 Watt
- Frequency Response
- 55 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - stereo x 2 - 20 Watt - 55 - 20000 Hz - 2-way - active
- Ocean blue
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - lithium polymer
- 28.8 cm x 13.6 cm x 13.2 cm
- 2.393 kg
- 1-year warranty
- Product Type
- Hands-Free Function
- Protection
- Waterproof
- Enclosure Colour
- Ocean blue
- Design Features
- Rugged
Speaker System
- Speaker Type
- Active
- Continuous Power
- 40 Watt
- 55 - 20000 Hz
- Signal-To-Noise Ratio
- 80 dB
- Connection Options
- Bi-amping
- Amplifier
- Integrated
- Bluetooth 4.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Compatible Software
- JBL Connect+
- Controls
- Power on/off, volume, call answer, play/pause
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 20 Watt - 55 - 20000 Hz CFR - 2-way - active
- Driver Details
- Speaker: 2 x tweeter driver - 0.79" , Speaker: 2 x woofer driver - 2.75" , Speaker: 2 x Passive Radiator
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A)
- Included Accessories
- Power adapter, strap
- IPX7
- Max Depth of Water Resistance
- 1 m
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - lithium polymer
- Capacity (Ah)
- 10000 mAh
- Run Time (Up To)
- 15 hour(s)
- Recharge Time
- 3.5 hour(s)
- 28.8 cm
- 13.6 cm
- 13.2 cm
- 2.393 kg
- Limited warranty - parts and labour - 1 year
