JBL Flip 6 - Red
JBL Flip 6 - Red
Quicklinx: HWVLWS00 Mfr#: JBLFLIP6RED
Colours:
£107.50 ex VAT
£129.00 inc VAT
As the perfect companion for powerful sound on the go, JBL Flip 6 boasts connectivity and durability. Join forces with your friends to make your sound bigger and better than ever with PartyBoost and feel at ease indoors and out with IP67 water and dustproof rating. With 12 hours of playtime, your JBL Flip 6 will last just as long as you do. A new audio configuration features dual passive radiators, powerful racetrack-shaped woofer and separate tweeter. JBL Flip 6 will deliver music with every stunning detail from bass, to mids, to highs.
  • Louder, more powerful sound
    The beat goes on with the JBL Flip 6 two-way speaker system, engineered to deliver loud, crystal clear, powerful sound. Its racetrack-shaped woofer delivers exceptional low frequencies and midrange, while a separate tweeter produces crisp, clear high-frequencies. Flip 6 also features optimized dual passive radiators for deep bass, fine-tuned with using Harman's advanced algorithm.
  • IP67 waterproof and dustproof
    To the pool. To the park. JBL Flip 6 is IP67 waterproof and dustproof, so you can take your speaker anywhere.
  • 12 hours of playtime
    Don't sweat the small stuff like charging your battery. JBL Flip 6 gives you up to 12 hours of playtime on a single charge.
  • Bold design
    Bold audio meets bold design. Big-sounding yet easy to carry, the design fits any personal style.
  • Crank up the fun with PartyBoost
    PartyBoost allows you to pair two JBL PartyBoost-compatible speakers together for stereo sound or link multiple JBL PartyBoost-compatible speakers to truly pump up your party.
  • USB charging protection
    Power up with peace of mind. JBL Flip 6 offers USB-C charging protection. That means a reminder sound will alert you to unplug if the connector detects water, salt, or any other chemicals.
  • Wireless Bluetooth streaming
    Wirelessly connect up to two smartphones or tablets to the speaker and take turns enjoying JBL Original Pro sound.
JBL Flip 6 - speaker - for portable use - wireless
Speaker - for portable use
Protection
Dustproof, waterproof
Enclosure Design
Passive radiator
Speaker Type
2-way - active
Amplifier
Integrated
Bluetooth
Fiesta red
Speaker battery rechargeable
17.8 cm x 6.8 cm x 7.2 cm
550 g
PartyBoost
Protection
Enclosure Colour
Fiesta red
Enclosure Design
Passive radiator
Speaker System
Speaker Type
2-way - active
Amplifier
Integrated
Bluetooth 5.1
Speaker System Details
Driver Details
Speaker: woofer driver - racetrack , Speaker: tweeter driver , Speaker: 2 x Passive Radiator
IP67
Power Source
Rechargeable
Run Time (Up To)
12 hour(s)
17.8 cm
6.8 cm
7.2 cm
550 g
Brand: JBL
