JBL Flip 6 - Grey
JBL Flip 6 - Grey
Quicklinx: HWVJWS00 Mfr#: JBLFLIP6GREY
Colours:
£107.50 ex VAT
£129.00 inc VAT
The JBL Flip 6 features innovation inside and out but remains true to its legendary predecessors. The new logo design, premium materials, and refreshed color range, house a brand new audio set up. JBL Flip 6 delivers even better JBL Pro Sound in the most stylish package yet.
As the perfect companion for powerful sound on the go, the JBL Flip 6 boasts connectivity and durability. Join forces with your friends to make your sound bigger and better than ever with PartyBoost and feel at ease indoors and out with IP67 water and dustproof rating. With 12 hours of playtime, your JBL Flip 6 will last just as long as you do.
A new audio configuration features dual passive radiators, powerful racetrack-shaped woofer and separate tweeter. The JBL Flip 6 delivers music with every stunning detail from bass, to mids, to highs.
  • Louder, more powerful JBL sound
    The beat goes on with the JBL Flip 6 2-way speaker system, engineered to deliver loud, crystal clear, powerful sound. Its racetrack-shaped woofer delivers exceptional low frequencies and midrange, while a separate tweeter produces crisp, clear high-frequencies. Flip 6 also features optimized dual passive radiators for deep bass, fine-tuned with using JBL's advanced algorithm.
  • IP67 waterproof and dustproof
    To the pool. To the park. JBL Flip 6 is IP67 waterproof and dustproof, so you can take your speaker anywhere.
  • 12 Hours of Playtime
    Don't sweat the small stuff like charging your battery. JBL Flip 6 gives you up to 12 hours of playtime on a single charge.
  • Crank up the fun with PartyBoost
    PartyBoost allows you to pair two JBL PartyBoost-compatible speakers together for stereo sound or link multiple JBL PartyBoost-compatible speakers to truly pump up your party.
  • JBL Portable app
    Maximize your audio experience with the JBL Portable app. Get updates and product support straight from your phone. Then unlock features, amplify your audio, or tweak your bass for total control over your sound.
  • USB charging protection
    Power up with peace of mind. The JBL Flip 6 offers USB-C charging protection. That means a reminder sound will alert you to unplug if the connector detects water, salt, or any other chemicals.
  • Wireless Bluetooth streaming
    Wirelessly connect up to 2 smartphones or tablets to the speaker and take turns enjoying JBL Original Pro sound.
  • Eco-friendly packaging
    JBL is committed to a more sustainable, earth-friendly packaging. The Flip 6 is packaged in a recyclable paper-based box, including the inner tray. The plastic hangtag is over 90% recycled and the exterior is printed with soy ink.
JBL Flip 6 - speaker - for portable use - wireless
Speaker - for portable use
Protection
Dustproof, waterproof
Enclosure Design
Passive radiator
Speaker Type
2-way - active
Amplifier
Integrated
Bluetooth
Greystone
Speaker battery rechargeable
17.8 cm x 6.8 cm x 7.2 cm
550 g
PartyBoost
Protection
Enclosure Colour
Greystone
Enclosure Design
Passive radiator
Speaker System
Speaker Type
2-way - active
Amplifier
Integrated
Bluetooth 5.1
Speaker System Details
Driver Details
Speaker: woofer driver - racetrack , Speaker: tweeter driver , Speaker: 2 x Passive Radiator
IP67
Power Source
Rechargeable
Run Time (Up To)
12 hour(s)
17.8 cm
6.8 cm
7.2 cm
550 g
Brand: JBL
