No wires. No hassles. The cord-free JBL TUNE 120TWS are powerful in sound thanks to a 5.8mm driver featuring JBL Pure Bass sound. The earbuds combined with the elegantly designed portable charging case provide 16 hours of unrestrained musical enjoyment. Ergonomically shaped, they also ensure long lasting comfort. Equipped with intuitive and handy controls that are conveniently located on each earpiece, including one click access to Siri and Google Now.
JBL Pure Bass sound
The 5.8mm driver featuring JBL Pure Bass sound provides a powerful punch to all your playlists. -
Truly wireless
Discover the freedom of a wireless lifestyle while on the go. Now listen to music, manage your calls or work out without the fear of tangled wires interrupting your groove. -
Hands-free stereo calls
Never miss your call during your daily commute or workout thanks to intuitive control for stereo hands-free calls and conveniently placed buttons on the earphones. Connect with Siri or Google Assistant with the push of a button. -
4h playback for earbuds + 12h for charging case
Your listening needs are met from the start of the day to its end. And if that's not enough, plug the earbuds into the elegantly designed portable charging case for just 15 minutes to get 1 extra hour of charge.
- JBL TUNE 120TWS - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Blue
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Radio Frequency Range
- 2.402 - 2.480GHz
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Stereo
- Sound Effects
- Pure Bass
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
- Impedance
- 14 Ohm
- Max Input Power
- 15 mW
- Controls
- Power on/off, answer/end, play/pause, next/previous track
- Intelligent Assistant
- Siri, Google Assistant, Bixby
- 1-year warranty
- Product Type
- True wireless earphones - Bluetooth - wireless
- 73 g
- Blue
Audio Output
- In-ear
- Dynamic
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Sound Effects
- Pure Bass
- 20 - 20000 Hz
- Max Input Power
- 15 mW
- Sensitivity
- 96 dB
- Impedance
- 14 Ohm
- Max Sound Pressure
- 96 dB
- Diaphragm
- 5.8 mm
Microphone
- Form Factor
- Built-in
- Sensitivity
- -38 dBV/Pascal
Remote Control
- Controls
Wireless Link
- 2.402 - 2.480GHz
- Modulation Type
- GFSK, 8-DPSK, DQPSK
Internet of Things (IoT)
- Included Accessories
- 3 pairs of ear tips (small, medium, large), charging cable, charging case (850 mAh)
- Battery
- Headphone battery rechargeable - Lithium Ion
- Capacity
- 85 mAh
- Run Time (Up To)
- 4 hour(s)
- Run Time Details
- Continuous playback (with included charging case): up to 16 hrs , Continuous playback: up to 4 hrs
- Recharge Time
- 2 hour(s)
- Limited warranty - 1 year
