Plug in and rock out with the JBL PBM100 Wired Microphone, the perfect vocal performance mic for your JBL PartyBox speaker. Engineered specifically to pair with the full line of JBL PartyBox speakers, the PBM100 delivers a sound experience like no other. Easy plug-n-play setup lets you instantly sing along to your favorite tunes. With the PMB100, you can turn parties into superstar sing-alongs guaranteed to create memories to last a lifetime. Let the party get started!
JBL-quality performance
Legendary JBL audio engineering in a vocal microphone. -
Easy to use
Just plug n' play with the PartyBox and sing-along. -
Cardioid polar pattern
The cardioid pattern effectively captures vocals and minimizes ambient noise making it ideal for vocal applications. -
Premium industrial design
Sleek, rugged built-to-last stage-quality casing. -
Wire mesh cap with windscreen
Surpresses windblasts and background noise so you can deliver a stellar performance without interference.
- JBL PBM100 - microphone
- Product Type
- Microphone
- Recommended Use
- Vocal
- Black
- Microphone Operation Mode
- Cardioid
- Product Type
- Microphone
- 18.8 cm
- Diameter
- 4.67 cm
- 110 g
- Black
- Recommended Use
- Vocal
Microphone
- Cardioid
- Connectivity Technology
- Wired
- Sensitivity
- -55 dBV/Pascal
- Impedance
- 600 Ohm
- Frequency Response
- 50 - 15000 Hz
- Connector Type
- Microphone (phone stereo 6.3 mm)
- Included Accessories
- 6.3 mm to 3.5 mm adapter
