JBL PartyBox Stage 320
Quicklinx: HX9TWS00 Mfr#: JBLPBSTAGE320UK
Select:
Rock out with powerful JBL Pro Sound from two 6.5" woofers that deliver clean, precise, deep bass even at top volume and a pair of 25mm dome tweeters that produce crystal clear highs. Indoors or out, you can fill a space the size of a tennis court with music.
  • Portable design
    Equipped with built-in carrying handles and wheels, the JBL PartyBox Stage 320 offers convenience for music enthusiasts on-the-go. Its design ensures your favorite tunes can travel with you, whether to a friend's house or an outdoor gathering.
  • Robust audio performance
    Featuring a 240 W integrated amplifier and a 2-way crossover channel, the Stage 320 delivers a powerful and clear audio experience. With dual woofer and tweeter drivers, it ensures a broad frequency response from 40 to 20,000 Hz, catering to all genres of music with precision.
  • Versatile connectivity
    This speaker supports both wired and wireless connections, including Bluetooth 5.4, making it adaptable to various audio sources. Whether streaming from a smartphone or connecting via USB, the Stage 320 simplifies audio playback.
  • Splashproof protection
    With an IPX4 splashproof rating, the JBL PartyBox Stage 320 is built to withstand splashes, making it perfect for pool parties, beach outings, or any event where spills might occur.
  • Interactive light show
    Enhance your music experience with the Stage 320's dynamic light show system. It synchronizes with your music to create an immersive audiovisual experience, perfect for parties and gatherings.
JBL PartyBox Stage 320 - party speaker - for portable use - wireless
Party speaker - for portable use
Media Content Source
USB-host
Protection
Splashproof
Speaker Type
2-way - active
Continuous Power
240 Watt
Amplifier
Integrated
Bluetooth
Audio Formats
WAV, WMA, MP3, FLAC
AC 100-240 V (50/60 Hz)
Speaker battery rechargeable - Lithium Ion
33.5 cm x 38.5 cm x 67 cm
16.5 kg
Auracast multi-speaker, AI Sound Boost, JBL Pro Sound
USB-host
Light
Light show system
Protection
Splashproof
Enclosure Colour
Design Features
Built-in wheels, built-in carrying handle
Speaker System
Speaker Type
2-way - active
Continuous Power
240 Watt
Frequency Response (-6dB)
40 - 20000 Hz
Signal-To-Noise Ratio
80 dB
Amplifier
Integrated
Bluetooth 5.4
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Compatible Software
JBL PartyBox
Audio Formats
WAV, WMA, MP3, FLAC
Controls
Bass, treble, echo, volume, bass boost, lights mode, speaker pairing
App-Controlled
Speaker System Details
Driver Details
Speaker: 2 x woofer driver - 6.5" , Speaker: 2 x tweeter driver - 1"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , Microphone/guitar audio input (phone 6.3 mm) , Microphone (phone 6.3 mm) , USB (4 PIN USB Type A) , Daisy chain audio input (mini-phone 3.5mm) , Daisy chain audio output (mini-phone 3.5mm)
IPX4, GFSK, Pi/4 DQPSK, 8DPSK
Power Source
Battery, Integrated power supply
Rechargeable - Lithium Ion
Capacity (Ah)
9444 mAh
Capacity (Wh)
68 Wh
Voltage Provided
7.2 V
Run Time (Up To)
18 hours
Recharge Time
3 hour(s)
33.5 cm
38.5 cm
67 cm
16.5 kg
