JBL Go3 Portable Speaker IPX67 - White
Quicklinx: G2SDWS00 Mfr#: JBLGO3WHT
Colours:
JBL Go 3 features bold styling and rich JBL Pro Sound. With its eye-catching edgy design, colorful fabrics and expressive details this is a must-have accessory for your next outing. Your tunes will lift you up with JBL Pro Sound, it's IP67 waterproof and dustproof so you can keep listening rain or shine, and with its integrated loop, you can carry it anywhere. JBL Go 3 looks as vivid as it sounds.
  • Original JBL Pro Sound
    JBL Pro Sound delivers surprisingly big audio and punchy bass from Go 3's ultra-compact size.
  • Bold style and ultra-portable design
    JBL Go 3's ultra-portable design goes great with the styles, and its colorful fabrics and expressive details make it look as great as it sounds.
  • Waterproof and dustproof
    To the pool. To the park. JBL Go 3 is IP67 waterproof and dustproof, so you can bring your speaker anywhere.
  • Wireless Bluetooth streaming
    Wirelessly stream music from your phone, tablet, or any other Bluetooth-enabled device.
JBL Go 3 - speaker - for portable use - wireless
Speaker - for portable use
Protection
Dustproof, waterproof
Speaker Type
Active
Continuous Power
4.2 Watt
Frequency Response
110 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker Details
Speaker - mono - 4.2 Watt - 110 - 20000 Hz - active
White
Power Options
USB charging
Speaker battery rechargeable - lithium polymer
8.75 cm x 4.13 cm x 7.5 cm
209 g
Protection
Enclosure Colour
White
Design Features
Built-in hang loop
Speaker System
Speaker Type
Active
Continuous Power
4.2 Watt
Frequency Response
110 - 20000 Hz
Signal-To-Noise Ratio
85 dB
Amplifier
Integrated
Bluetooth 5.1
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Speaker System Details
Speaker Details
Speaker - mono - 4.2 Watt - 110 - 20000 Hz CFR - active
Driver Details
Speaker: full-range driver
Connector Type
DC power input (USB Type-C)
USB-C cable
IP67
Power Source
Options
USB charging
Rechargeable - lithium polymer
Capacity (Wh)
2.775 Wh
Run Time (Up To)
5 hour(s)
Recharge Time
2.5 hour(s)
8.75 cm
4.13 cm
7.5 cm
209 g
