The JBL Charge 4 is a musical force to be reckoned with, boasting hours of playtime and the ability to charge any smart device through the speaker's charging port. No more worrying about cutting that playlist short, the music will be going strong as long as the party.
Wireless Bluetooth streaming
Wirelessly connect to up to 2 smartphones or tablets to the speaker and take turns enjoying powerful sound. -
Waterproof design
Take the speaker to the beach or the pool without worrying about spills or even submersion in water. -
Durable fabric and rugged materials
The durable fabric material and rugged rubber housing allows for speakers to outlast any adventure.
- JBL Charge 4 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Waterproof
- Speaker Type
- Active
- Nominal Output Power (Total)
- 30 Watt
- Max Output Power
- 30 Watt
- Frequency Response
- 60 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - stereo x 2 - active
- Ocean blue
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Power Options
- USB charging (powerbank function)
- Battery
- Speaker battery rechargeable
- Product Type
- Protection
- Waterproof
- Enclosure Colour
- Ocean blue
Speaker System
- Speaker Type
- Active
- 30 Watt
- Max Output Power
- 30 Watt
- 60 - 20000 Hz
- Signal-To-Noise Ratio
- 80 dB
- Amplifier
- Integrated
- Bluetooth 4.2
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Compatible Software
- JBL Connect+
Speaker System Details
- Speaker Details
- Driver Details
- Speaker: 2 x full-range driver , Speaker: 2 x Passive Radiator
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , USB (power only) (4 pin USB Type A (power only))
- IPX7
- Max Depth of Water Resistance
- 1 m
- Power Source
- Battery
- Options
- Rechargeable
- Capacity (Ah)
- 7500 mAh
- Run Time (Up To)
- 20 hour(s)
