The Jabra Motion UC's intuitive controls, motion sensing technologies, quick NFC pairing and incredible 100 metres range from the PC, make it a smart, stylish choice for mobile professionals. Comes with a compact charging kit that doubles as a carrying case for easy storage.
A high-end Bluetooth headset features excellent intelligent technology that allows you to communicate easily, both in the office and on the go.
Jabra Motion is second to none in terms of innovative features and future proof technology. Designed for maximum convenience and providing superior wearing comfort, it helps simplify your busy lifestyle. It is the only headset you'll ever need. Built-in motion sensors reacts to your movements and different sound environments, enabling intuitive call control, unsurpassed battery performance and superior audio quality.
Superior sound
Get best-in-class sound quality. Built-in motion sensor and advanced microphones adapt the sound to your surroundings. Enjoy crystal-clear, high-definition calls even in noisy or windy conditions. -
All-day comfort
Get maximum comfort with a behind-the-ear design and flexible materials that hug your ear. Find the perfect fit by adjusting the speaker and flipping it to fit either ear. -
Smart motion sensor
Answer calls by simply picking up the headset. When lying still, the motion sensor activates a "Power Nap" mode to save battery. Lift the headset, and it's ready to go again.
- Jabra Motion UC+ - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics, computer
- Headphones Form Factor
- Ear-bud - over-the-ear mount
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Sound Output Mode
- Mono
- Active Noise Canceling
- Microphone
- Boom
- Controls
- Mute
- Product Type
- 17.5 g
- Recommended Use
- Max Operating Distance
- 100 m
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
- Sound Output Mode
- Mono
- Active Noise Cancelling Technology
- Noise Blackout
Microphone
- Boom
Remote Control
- Controls
- Mute
Wireless Link
- Transmission Range
- 100 m
- Included Accessories
- Bluetooth USB adapter, charging case, 3 pairs of gel ear tips
- Cable Details
- USB cable
- Battery
- Headset battery rechargeable
- Included Qty
- 1
- Run Time (Up To)
- 7 hour(s)
- Standby Time
- 360 hours
Jabra USB-A to USB-C Adapter | In Stock | £12.40 |
