Jabra Evolve2 40 SE USB MS Stereo Headset
Quicklinx: HJS9WS00 Mfr#: 24189-999-999
Recommended Use: Phone, Phone, Computer
Connectivity: Wired
Earcover : Binaural
£95.59 ex VAT
£114.70 inc VAT
The Jabra Evolve2 40 SE MS Stereo headset is designed for professionals who require high-quality audio and seamless communication in their work environment. Featuring a boom microphone with noise-canceling capabilities and a frequency response tailored for both multimedia and communication, this headset delivers clear sound. Wired connectivity provides a stable connection without the concern of battery life, while intuitive controls allow for easy management of calls and music. Certified for Microsoft Teams, it integrates smoothly into your workflow, enhancing productivity. The inclusion of SafeTone technology ensures your hearing is protected during long hours of use. With its durable aluminum construction and comfortable design, the Jabra Evolve2 40 SE MS Stereo is a reliable companion for the modern professional.
  • Cancels more noise than ever before
    Put on your Evolve2 40 and feel the noise around you instantly fade. Memory foam oval ear cushions and pioneering angled design cancel 48% more of the noise around you.
  • Guard your concentration zone with an enhanced busylight
    Improved busylight is four times more visible, allowing you to be seen from every angle, for even fewer interruptions. So you can work in peace.
  • Make good calls when it matters
    The incredible call performance of the Evolve series is now even better; Evolve2 40 is a corded headset with an advanced digital chipset and three strategically placed professional microphones, for 35% less background conversation noise on your calls.
  • UC-certified means UC-satisfied
    When collaboration is easy, everyone is happy, with both their UC platform and their headset. Evolve2 40 is available in a Microsoft-Teams variant, for truly seamless communication.
  • Bigger speakers, better chipset, brilliant audio
    You'll never miss a thing, thanks to powerful leak-tolerant 40 mm speakers and the advanced digital chipset ever, delivering audio that always keeps you in the loop.
  • Optimized for all-day comfort
    Jabra designed the perfect shape using biometric measurements from hundreds of heads, added soft memory foam cushions that mold to your ear's natural contours, and assembled it using durable, premium materials.
  • Future-proof tech that gets better with age
    Upgradeable platform that will add even more value to your investment with future firmware upgrades through Jabra Xpress.
Jabra Evolve2 40 SE MS Stereo - headset - USB-A
Headset - wired - USB-A
Recommended Use
Phone, computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 117 dB
Max Input Power
30 mW
Noise Isolating
Microphone
Boom
Microphone Noise Cancelling
Microphones Included
3
Controls
Mute, volume, answer/end, play/pause, next/previous track, flip-to-mute
Environmental Standards
TCO Certified Headsets 9
Software Certification
15.7 cm
6.05 cm
18.6 cm
188 g
Body Material
Aluminium
Headband Material
Foam, silicone
Earpad Material
Leatherette, foam
Recommended Use
Audio Output
On-ear
Wired
Bluetooth Audio Codec
SBC
Sound Output Mode
Stereo
Noise Isolating
Frequency Response
20 - 20000 Hz
Max Input Power
30 mW
Sensitivity
117 dB
Diaphragm
40 mm
Volume Limiting Function
Busy light, SafeTone technology, Jabra Direct, Jabra Xpress
Audio Output Details
Multimedia - 20 - 20000 , Communication - 100 - 14000
Microphone
Boom
Headset microphone
3
Sensitivity
-26 dBFS/Pa
Frequency Response
100 - 14000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Cable
Cable Length
1.2 m
Soft pouch
Cable Details
Headset cable - 1.2 m
Plug and Play, FSC
Sustainability Information
TCO Certified
Shipping Width
18.85 cm
Shipping Depth
5.5 cm
Shipping Height
21.7 cm
HJS9 Jabra Ear Cushions for Evolve2 65/40 (6pcs) - Black In Stock £52.42
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
Brand: Jabra
