- Plug-and-Play connectivity to your computer or mobile device via USB
- 3-microphone technology for outstanding call performance
- Instant noise isolation for improved focus in noisy surroundings
- Additional features available via Jabra Xpress and Jabra Direct
- Powerful 40 mm speakers deliver richer sound for a more immersive audio experience
- 360° busylight on both earcups is visible from all angles, acting as a do-not-disturb sign and protecting your focus
- Move boom arm up to mute or down to unmute or answer call
Cancels more noise than ever before
Put on your Evolve2 40 and feel the noise around you instantly fade. Memory foam oval ear cushions and pioneering angled design cancel 48% more of the noise around you. -
Guard your concentration zone with an enhanced busylight
Improved busylight is four times more visible, allowing you to be seen from every angle, for even fewer interruptions. So you can work in peace. -
Make good calls when it matters
The incredible call performance of the Evolve series is now even better; Evolve2 40 is a corded headset with an advanced digital chipset and three strategically placed professional microphones, for 35% less background conversation noise on your calls. -
UC-certified means UC-satisfied
When collaboration is easy, everyone is happy, with both their UC platform and their headset. Evolve2 40 is available in a Microsoft-Teams variant, for truly seamless communication. -
Bigger speakers, better chipset, brilliant audio
You'll never miss a thing, thanks to powerful leak-tolerant 40 mm speakers and the advanced digital chipset ever, delivering audio that always keeps you in the loop. -
Optimized for all-day comfort
Jabra designed the perfect shape using biometric measurements from hundreds of heads, added soft memory foam cushions that mold to your ear's natural contours, and assembled it using durable, premium materials. -
Future-proof tech that gets better with age
Upgradeable platform that will add even more value to your investment with future firmware upgrades through Jabra Xpress.
- Jabra Evolve2 40 SE MS Stereo - headset - USB-A
- Product Type
- Headset - wired - USB-A
- Recommended Use
- Phone, computer - communication
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 117 dB
- Max Input Power
- 30 mW
- Noise Isolating
- Microphone
- Boom
- Microphone Noise Cancelling
- Microphones Included
- 3
- Controls
- Mute, volume, answer/end, play/pause, next/previous track, flip-to-mute
- Environmental Standards
- TCO Certified Headsets 9
- Software Certification
- Certified for Microsoft Teams
- 2-year warranty
- Product Type
- 15.7 cm
- 6.05 cm
- 18.6 cm
- 188 g
- Body Material
- Aluminium
- Headband Material
- Foam, silicone
- Earpad Material
- Leatherette, foam
- Recommended Use
Audio Output
- On-ear
- Wired
- Bluetooth Audio Codec
- SBC
- Sound Output Mode
- Stereo
- Noise Isolating
- 20 - 20000 Hz
- Max Input Power
- 30 mW
- Sensitivity
- 117 dB
- Diaphragm
- 40 mm
- Volume Limiting Function
- Busy light, SafeTone technology, Jabra Direct, Jabra Xpress
- Audio Output Details
- Multimedia - 20 - 20000 , Communication - 100 - 14000
Microphone
- Boom
- Form Factor
- Headset microphone
- 3
- Sensitivity
- -26 dBFS/Pa
- 100 - 14000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- Headset (4 PIN USB Type A)
Cable
- Cable Length
- 1.2 m
- Included Accessories
- Soft pouch
- Cable Details
- Headset cable - 1.2 m
- Plug and Play, FSC
Sustainability Information
- TCO Certified
- Limited warranty - 2 years
- Shipping Width
- 18.85 cm
- Shipping Depth
- 5.5 cm
- Shipping Height
- 21.7 cm
Jabra Ear Cushions for Evolve2 65/40 (6pcs) - Black | In Stock | £68.29 |
