iT7 Audio iT7x2 Bluetooth Headphones with NFC - Matte Black
Quicklinx: 9NC2WS00 Mfr#: 33071IT71
The All New iT7x2 Bluetooth® Headphones with NFC Technology For One Touch Pairing. These headphones with a built-in microphone allow you to make & take calls. Comfortable, stylish and robust with amazing sound that brings the artist to you.
The iT7x2 is the latest addition to the ground breaking iT7 audio family. Using the very latest 4.0 Bluetooth® technology, these headphones introduce new standards in wireless sound and raise the bar in terms of comfort and style. iT7x2 headphones feature the state of the art CSR aptX® chipset which delivers a robust Bluetooth® signal and full-range sound. This means that you get clear highs right through to the fullest of lows and all in a lightweight, robust and flexibledesign.
The iT7x2 embraces the latest connectivity technology, with one touch pairing via Near Field Communication (NFC). This wireless technology uses radio fields for quick connection and is becoming a standard feature in smartphone handsets.
Features:
  • Wireless Bluetooth® technology for the freedom to listen and make calls on the move
  • Bluetooth® 4.0
  • Maximum optimum operating range 20 metres
  • Advanced noise reduction
  • Dynamic, cushioned cans
  • High definition built-in microphone
  • Rechargeable Lithium battery
  • Extendable and foldable design
  • Standby time: up to 400 hours
  • Continuous usage time: up to 22 hours
  • Multi-function button, volume +/- button and previous/next song button
  • Compatible with iPhone, iPod, Samsung, HTC, BlackBerry and most other Bluetooth® enabled devices
  • Touch.Connect.Play (only compatible with NFC enabled handsets)
"The design is excellent, the choice of colours giving you a chance to match up with your iPod Touch, but audio and comfort hasn't been left out either. Overall, the iT7x2 are a solid pair of wireless headphones with a touch of flair"
-iT7x2 Headphones Review on T3.com
iT7 Audio x2 - headset
Headset - Bluetooth - wireless - NFC
Recommended Use
Portable electronics
Headphones Form Factor
Full size
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Stereo
Microphone
Built-in
Controls
Volume
Recommended Use
Max Operating Distance
20 m
Audio Output
Full size
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Stereo
Remote Control
Controls
Volume
Wireless Link
Transmission Range
20 m
Headset battery rechargeable - lithium
Run Time (Up To)
22 hour(s)
Standby Time
400 hours
