PM43 mid-range industrial label printers are ready to perform, designed to maximize your uptime. Count on PM43 to deliver quick deployment and proven reliability. Ideal for a wide range of applications within the distribution center, warehouse and manufacturing environments.
Ready
PM43 is ready to deliver maximum uptime. Reduce your total workforce training and device support needs with immediate notifications via the printer and the elimination of reconfiguration due to UI tampering. -
Reliable
As the 3rd generation of Intermec industrial printers, the rugged PM43 incorporates features that increase uptime and reduce maintenance costs. Strong all-metal construction is perfect for harsh industrial environments and the metal media door with innovative latch system ensures media is protected. -
Perform
PM43 is ready to perform. With the print speed of 12 ips, you'll gain a clear productivity advantage. PM43 helps to reduce labeling errors and increase process efficiencies. Printer stand-alone applications, developed through the embedded programming language, directly control other devices such as scanners, scales, keyboards and other peripherals helping you decrease infrastructure costs and complexity.
- Honeywell PM43 - label printer - B/W - direct thermal / thermal transfer
- Printer Type
- Label printer - direct thermal / thermal transfer - B/W
- 15.8 kg
- Localisation
- Europe
- Max Media Size
- Roll (11.4 cm)
- Min Media Size (Custom)
- 19.1 mm
- Max Media Size (Custom)
- 114.3 mm
- Print Speed
- Up to 300 mm/sec - max speed
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB, LAN, serial
- RAM Installed (Max)
- 128 MB SDRAM
- Flash Memory Installed (Max)
- 128 MB
- Language Simulation
- ZPL, Intermec Printer Language (IPL), DSim (Datamax Interpreter), ZSim, Extensible Mark-up Language (XML), DPL
- Barcodes
- EAN/JAN, Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, ISBT 128, GS1 DataBar, QR code, MaxiCode, Aztec code, HIBCC, LOGMARS, MicroPDF417, Codabar, Code 128, Code 11, Code 16K, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, Plessey, AIAG, Standard 2 of 5, Grid Matrix Code
- Media Type
- Labels, linerless labels, fanfold paper, tag stock, tickets
- Networking
- Print server - Ethernet, Fast Ethernet
- Printer Features
- RFID ready, USB host
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- 28.4 cm x 48.4 cm x 29.5 cm
- Printer Type
- Label printer - direct thermal / thermal transfer - monochrome
- Localisation
- Europe
Printer
- Print Speed
- Up to 300 mm/sec - max speed - 203 dpi
- Built-in Devices
- Touch screen
- Connectivity Technology
- Wired
- Interface
- USB, LAN, serial
- 203 dpi
- Barcodes
- Printer Features
RAM
- 128 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 128 MB
Media Handling
- Media Type
- Max Media Size
- Roll (11.4 cm)
- 19.1 mm
- 114.3 mm
- Media Sizes
- Roll (1.9 - 11.4 cm)
- Max Printing Width
- 108 mm
- Media Weight
- 57.6 g/m² - 250 g/m²
- Roll Maximum Outer Diameter
- 213 mm
- Roll Core Diameter
- 76.2 mm, 38.1 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (11.4 cm)
- Networking
- Print server
- Data Link Protocol
- TCP/IP, UDP/IP, ICMP/IP, LPR/LPD, SMTP, FTP, BOOTP, DHCP
- Remote Management Protocol
- SNMP 1, SNMP 3, SNMP 2c, HTTP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x LAN - RJ-45 , 1 x USB - 4 pin USB Type A
- Included Accessories
- Fixed media hanger
- FCC Class A certified, UL, C-Tick, cUL, EN55022, CCC, RoHS
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 300 Watt
- Power Consumption Stand by / Sleep
- 9 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
- 28.4 cm
- 48.4 cm
- 29.5 cm
- 15.8 kg
