The Intel SSD DC S3500 Series combines fast, consistent read performance with strong data protection and low active power levels to provide superior quality of service for video conferencing, big data analytics, or virtual client applications. Consistently low read latencies of 50 µs typical (500 µs max for 99.9% of the time) along with a tight distribution of up to 75,000 input/output per second (IOPS) delivers a high-performance, reliable, and efficient SSD specifically designed for data center application upgrades.
Robust durability
Designed to withstand tough conditions, this solid-state drive boasts a shock tolerance of 1000 g @ 0.5 ms for both operating and storage, ensuring your data remains safe even with unexpected impacts. -
Enhanced security
Equipped with 256-bit AES compliance and enhanced power loss data protection, this drive ensures your sensitive data is securely encrypted and protected against unexpected power outages. -
Efficient performance
With a data transfer rate of 600 MBps and internal data rates of 500 MBps (read) and 410 MBps (write), this SSD delivers efficient performance for both read and write operations, making it ideal for heavy-duty computing tasks. -
High reliability
Featuring a mean time between failures (MTBF) of 2,000,000 hours, this SSD offers reliability and longevity, reducing the need for frequent replacements and ensuring consistent performance over time. -
Optimized for compatibility
This SSD is compatible with Windows 7, ensuring seamless integration with your existing system without the need for additional drivers or software installations.
- Intel Solid-State Drive DC S3500 Series - solid state drive - 480 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 480 GB
- NAND Flash Memory Type
- 20nm multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- End-to-end data protection (ANSI), SMART Command Transport (SCT), Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, S.M.A.R.T., 256-bit AES
- 69.85 mm x 100.45 mm x 7 mm
- 72 g
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Capacity
- 480 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.45 mm
- 7 mm
- 72 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 500 MBps (read) / 410 MBps (write)
- 4KB Random Read
- 75000 IOPS
- 4KB Random Write
- 11000 IOPS
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^17
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 22 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 4.3 Watt (active) , 0.9 Watt (idle)
- UL, VCCI, C-Tick, BSMI, RoHS, KCC
- Limited warranty - 5 years
- 0 °C
- 70 °C
- 5 - 95%
- Shock Tolerance
- 1000 g @ 0.5ms (operating) / 1000 g @ 0.5ms (non-operating)
- Vibration Tolerance
- 2.17 g @ 5-700 Hz (operating) / 3.13 g @ 5-800 Hz (non-operating)
