iiyama X2788QS-B1 27" 2560x1440 5ms VGA DVI DP Monitor
Quicklinx: CW1SWS00 Mfr#: X2788QS-B1
Do you spend most of your workday joggling between multiple applications and windows and there is simply never enough of space on the screen? If the answer is yes - you've come to the right place. The X2788QS can easily accommodate more information on the screen. Problem solved. In addition, the IPS technology panel offers accurate and consistent color reproduction with wide viewing angles and high contrast and brightness values guaranteeing the monitor will provide excellent performance for photographic and web design. Let your creativity loose, Iiyama X2788HS will not let you down.
iiyama ProLite X2788QS-B1 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Tilt
Voltage
64.35 cm x 24.2 cm x 46.2 cm
4.4 kg
DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B, CU
Display Type
Energy Class
Class C
Diagonal Size
27"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 100 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Japanese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
4.4 kg
Audio
Speakers - stereo
Output Power / Channel
2.5 Watt
DisplayPort , DVI , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-3/+20
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable
Input Voltage
Power Consumption (Typical)
41 Watt
