iiyama ProLite E1780SD 17" 1280x1024 DVI LCD Monitor
Quicklinx: 9SN0WS00 Mfr#: E1780SD-B1
Select:
  • 17"
The 17" ProLite E1780SD is a LED-backlit monitor with good response time, high contrast and sRGB and gamma correction functions that permit even the finest nuances of color to be set accurately.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
  • Advanced Contrast Ratio (ACR)
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite E1780SD-B1 - LED monitor - 17"
LED-backlit LCD monitor - 17"
Energy Class
Class E
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
37 cm x 17.8 cm x 37.95 cm
2.6 kg
Environmental Standards
ENERGY STAR Qualified
VESA DPMS, GOST-R, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class E
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
2.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D , Audio line-in
Mechanical
Tilt
Tilt Angle
20
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
Input Voltage
12 kWh/1000h
Power Consumption (Typical)
14 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP/Vista, Microsoft Windows 7 / Windows 8
Sustainability Information
ENERGY STAR Certified
