iiyama B2780HSU-B1 27" LED 1920x1080 VGA DVI HDMI Monitor
Quicklinx: 87ZMWS00 Mfr#: B2780HSU-B1
Select:
  • 27"
The ProLite XB2780HSU is a 27'‘, eco friendly LED monitor featuring MVA Panel technology. This sophisticated technology provides wide viewing angles and offers superb color performance including superior black and white display. A 5000:1 Native Contrast Ratio means the ProLite XB2780HSU is ideal for Photographic Design and Web Design. Featuring Full HD 1920 x 1080 resolution with VGA, DVI, HDMI signal connectivity and a 4 port USB-HUB, this screen is compatible with a wide range of systems and applications, making it an excellent choice for Universities, Corporate, Financial and Design Markets. The ergonomic stand offers 11cm height adjustment, pivot and swivel.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
  • ACR
    Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • HDMI
    HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals.
  • VESA
    VESA mount compliance means you can easily mount your monitor to a wall.
  • PIVOT
    Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen.
  • OverDrive on/off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • Speakers
    This monitor is equipped with two high quality stereo speakers.
  • HAS
    A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
Iiyama ProLite B2780HSU - LED monitor - 27"
Aspect Ratio
Widescreen
Native Resolution
1920 x 1080
Display Position Adjustments
Swivel, tilt
Display Type
Diagonal Size
27"
Aspect Ratio
Widescreen
Native Resolution
1920 x 1080
Audio
Speakers - stereo
Mechanical
Swivel, tilt
Environmental Standards
ENERGY STAR Qualified
