The HP StorageWorks Ultrium 920 Tape Drive is the highest capacity, fastest performance half-height tape drive in the StorageWorks family based on HP's third generation LTO technology. The Ultrium 920 delivers a compressed storage capacity of 800 GB per data cartridge and a compressed data transfer rate of 432 GB per hour, two and a half times faster than the previous generation Ultrium 448 tape drive. Multiple drive models are available for the compact, half-height Ultrium 920 Tape Drive including internal, external, and 1U rack-mount model. The Ultrium 920 Tape Drive is fully read and write compatible with all second-generation Ultrium media and offers further investment protection through its backward-read compatibility with first-generation Ultrium media.
- HPE StorageWorks Ultrium 920 - tape drive - LTO Ultrium - SAS
- Tape drive
- Recording Standard
- LTO Ultrium 3
- Enclosure Type
- Internal
- Interface Type
- SAS
- 14.5 cm x 20.6 cm x 4.1 cm
- 1.5 kg
- Carbonite
- Storage Removable
- LTO Ultrium - 5.25" x 1/2H
- Storage Removable Capacity
- 400 GB (native) / 800 GB (compressed)
- Supported Tape Cartridges (Read and Write)
- Ultrium 2, Ultrium 3
- Data Transfer Rate (native)
- 60 MBps (216 GBph)
- Data Transfer Rate (compressed)
- 120 MBps (432 GBph)
- OS Required
- IBM AIX, SunSoft Solaris, HP-UX, Novell NetWare, Red Hat Linux, Microsoft Windows, UnitedLinux
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Designed For
- ProLiant DL120 G7, DL165 G5, DL165 G7, DL180 G5, DL185 G5, DL320 G5p, DL360 G5, DL365, DL365 G5, DL370 G6, DL380 G6, DL385 G2, DL385 G5, DL785 G5, ML110 G6, ML110 G7, ML115 G5, ML150 G6, ML330 G6, ML350 G5, ML350 G6, ML370 G6; StorageWorks Rack-Mount Kit Ultrium 1760
- Tape drive - LTO Ultrium
- LTO Ultrium 3
- Enclosure Type
- Internal
- Interface Type
- SAS
- Enclosure Colour
- Carbonite
- 14.5 cm
- 20.6 cm
- 4.1 cm
- 1.5 kg
Storage Removable
- Capacity
- Average Seek / Access Time
- 64 sec
- Buffer Size
- 64 MB
- 1 x SAS
- Compatible Bay
- 1 x front accessible - 5.25" x 1/2H
- Media Included Qty
- 1
- Cables Included
- 1 x SAS cable
- MTBF
- 250,000 hour(s)
- TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15
- Software Included
- Drivers & Utilities, HP StorageWorks Library and Tape Tools, HP StorageWorks Data Protector Express Single Server
- OS Required
- Limited warranty - parts - 3 years - response time: next day , Technical support - phone consulting - 3 years
- 10 °C
- 40 °C
- 20 - 80%
- Designed For
- HPE ProLiant DL120 G7, DL165 G5 Special Server, DL165 G7 Base, DL165 G7 Performance, DL180 G5 Special Server, DL185 G5 Special Server, DL320 G5p, DL360 G5, DL360 G5 Entry, DL360 G5 Performance, DL365 Base, DL365 Entry, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL365 Performance, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL385 G2 Base, DL385 G2 Entry, DL385 G2 High Performance, DL385 G5 Entry, DL785 G5, ML110 G6, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML115 G5, ML150 G6, ML150 G6 Base, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server, ML370 G6, ML370 G6 Base, ML370 G6 Entry , HPE StorageWorks Rack-Mount Kit Ultrium 1760 Drive
