HPE DAT 160 USB INTERNAL TAPE DRIVE
Quicklinx: 8X44WS00 Mfr#: Q1580B
£604.38 ex VAT
£725.25 inc VAT
Protect your small or medium-sized business, remote office or workgroup with HP DAT Tape Drives offering the ability to store up to 160 GB of compressed data on a single cartridge at speeds of up to 49.3 GB/hr (assuming 2:1 data compression). Low ongoing cost of ownership is provided through low-cost, durable DAT media and backward compatibility which delivers a seamless upgrade path from older drives. HP DAT Tape Drives are now onlt available with 160 GB of capacity with interface types, SCSI, SAS and USB, making them compatible with virtually any server environment. DAT Tape Drives come complete with data and cleaning cartridge, the option to download Yosemite Server Backup Basic backup and recovery software (for a single Windows or Linux server), and HP Library and Tape Tools.
  • High Performance Backup Solution That Fits Most Environments
    Provides a balance of price and performance for small and medium business environments and enterprise workgroups. HP DAT 160 Tape Drives can store up to 160 GB on a single cartridge, backing up to 49.3 GB/hr on a single DAT 160 cartridge in around four hours.Available as external or internal models to fit servers, workstations, and rack-mount kits. SAS, SCSI or USB 2.0 interfaces for universal plug and play.Visit us on the web for the latest information on HP Backup Compatibility.Helps prevent unauthorized access of tape media (lost or stolen cartridges). Tape drive based encryption avoids performance degradation associated with host based encryption.
  • Reduce Your Backup Costs
    Low-cost is driven by low-cost durable DAT media, and ongoing low-cost of ownership.As the most popular backup technology of all time, DAT provides investment protection through a proven track record of reliability and backwards compatibility.
  • Complete Backup Solution
    Restores your entire ProLiant system at the touch of a button without the need for system disks or software CDs. Visit HP One-Button Disaster Recovery (OBDR) Solution for the latest information.Provides a complete, easy-to-use backup solution that includes DAT media, cleaning cartridge, and the option to download Yosemite Server Backup Basic Software, to allow users to protect their data without any additional purchases.
HPE DAT 160 - tape drive - DAT - USB 2.0
Tape drive
Recording Standard
DAT-160
Enclosure Type
Internal
Interface Type
USB 2.0
14.5 cm x 18.3 cm x 4 cm
950 g
Storage Removable
DAT - 5.25" x 1/2H
Storage Removable Capacity
80 GB (native) / 160 GB (compressed)
Supported Tape Cartridges (Read and Write)
DDS-4, DAT-72, DAT-160
Data Transfer Rate (native)
6.9 MBps (25 GBph)
Data Transfer Rate (compressed)
13.8 MBps (50 GBph)
Linux, Microsoft Windows
ProLiant DL360e Gen8, DL360p Gen8, DL380e Gen8, DL380p Gen8, DL385p Gen8, ML310e Gen8, ML350e Gen8, ML350p Gen8
Tape drive - DAT
Recording Standard
DAT-160
Enclosure Type
Internal
Interface Type
USB 2.0
14.5 cm
18.3 cm
4 cm
950 g
Storage Removable
DAT - 5.25" x 1/2H
Recording Standard
DDS-4, DAT 72, DAT 160
6.9 MBps (25 GBph)
13.8 MBps (50 GBph)
Average Seek / Access Time
50 sec
Buffer Size
16 MB
1 x USB 2.0
Compatible Bay
1 x front accessible - 5.25" x 1/2H
Media Included Qty
1
Cleaning cartridge
3 x USB cable
MTBF
125,000 hour(s)
TUV, VCCI, C-Tick, BSMI, EN 60950, RRL, IEC 60950, CISPR 22, CSA 22.2 No. 60950, FCC, AS/NZS, cCSAus
10.3 Watt
Software Included
Yosemite Backup Basic
5 °C
20 - 80%
HPE ProLiant DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server
