Does your small-to-medium business need affordable storage that's easy to manage, keeps your business up and running, and scales as your business needs grow? The HPE StoreVirtual 3000 Storage is an advanced storage architecture designed with simplicity in mind to offer a highly virtualized backend and a single storage capacity pool for superior efficiency. It offers a single screen to manage the platform via an intuitive GUI with a common look and feel with other Hewlett Packard Enterprise user experiences. It delivers an affordable, granular building block approach with an entry-level unit that scales when you need it. Such flexible scaling capabilities give you investment protection and extend ROI in a world where throw-away mentality is still common. This hardware platform runs the StoreVirtual operating system providing unique scalability, resiliency, and management capabilities to deliver a cost-effective, shared storage system for a wide range of SMB customers.
Next-gen, Multi-controller Architecture lets You Start Small and Flexibly Accelerate Performance
An HDD-only base configuration with the option to add flash lets you flexibly grow performance, capacity, data resiliency, and file protocol options as your needs change, providing investment protection and extending your ROI.Adding a little flash lets you supercharge your apps. Optional Adaptive Optimization software allows the system to react automatically to real-time I/O fluctuations so that, as workloads change, your most frequently accessed data lands on flash for app acceleration. -
Deploy Your Storage in Minutes and Manage it with Zero Learning Curve
A single screen lets you manage multiple systems using an intuitive GUI that offers a simple, consumer-driven management experience designed with HPE ProLiant server users in mind.A powerful, proactive cloud-based analytics engine makes storage optimization a snap while built-in best practices algorithms make sure you get the most out of your storage investment.Developed with a highly virtualized 12 Gb SAS back-end and a single pool of storage capacity to offer superior efficiency. -
Apply 5 9's Availability When and Where You Need It
Designed from the ground up to provide user-selectable resiliency across systems and sites to keep applications up and running while controlling costs.With over 2,000 snapshots available in the base system, users will have the flexibility to fine-tune disaster recovery/business continuity (DR/BC) options to best fit their environment.Multiple unique replication and data availability features bring 99.999% availability down into the entry-level storage category. App-integrated, app-aware snapshots simplify disaster recovery.Synchronous replication between systems and sites lets you balance cost and resiliency. -
Start Small and Grow Along Multiple Dimensions
Seamlessly scales to meet changing performance and/or capacity needs. For added versatility, you can even add file protocol support with an optional file gateway.HPE StoreVirtual Migration Manager software lets you simplify and de-risk of workload migrations from HPE MSA and HPE StoreVirtual 4000 platforms.Leverages the same field-proven composable data fabric that is shared across HPE StoreVirtual systems and VSA software running on ProLiant, HPE Hyperconverged appliances, and HPE Synergy.By using the same software-defined storage operating system across this composable data fabric, HPE's vision is to provide customers the freedom to grow in any direction, at any time, across any form factor or consumption model.
- HPE StoreVirtual 3200 SFF - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 2U
- Total Array Capacity
- 1.2 TB
- Max Supported Capacity
- 288 TB
- Interface
- iSCSI (10 GbE)
- Maximum LUNs
- 2
- Installed Devices / Modules Qty
- 25 (max)
- Supported Drives
- SAS-3
- Storage Controller
- RAID (SAS 12Gb/s) - RAID 0, 5, 6, 10
- Storage Controller Quantity
- 2
- Hard Drive
- SAS 12Gb/s - hot-swap
- OS Required
- Microsoft Windows Server 2012, VMware ESXi 5.x, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2012 with Hyper-V, Ubuntu 12.04 LTS Server Edition, VMware ESXi 6.0
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- 48.3 cm x 59.7 cm x 8.8 cm
- 26.3 kg
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- Supported Devices / Modules Qty
- 25
- Supported Drives
- SAS-3
Storage
- 1.2 TB
- 288 TB
- HDD Array External Interface
- iSCSI (10 GbE)
- Maximum LUNs
- 2
- CPU
- 2 x
RAM
- Installed Size
- 16 GB
Storage Controller
- RAID
- Installed Qty
- 2
- Interface Type
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Cache / Buffer Size (Max)
- 2 GB
- RAID Level
- RAID 0, RAID 5, RAID 6, RAID 10
Storage Controller (2nd)
- Installed Qty
- 2
Hard Drive
- Hot-swap
- Interface Type
- SAS 12Gb/s
- Expansion Bays
- 25 (total) / 25 (free) x hot-swap - 2.5" SFF
- Expansion Slots
- 25
- 4 x SCSI - SFP+ , 1 x management , 1 x management - 9 pin Micro-USB Type B , 1 x management - RJ-45 , 4 x USB , 1 x Ethernet 1000
- OS Required
- BSMI CNS 13438 Class A, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, UL 60950, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, RoHS, China RoHS, AS/NZS CISPR22:2006 Class A, VCCI - V-3/2014.04, ICES-003 issue 5 Class A, FCC CFR47 Part 15 B Class A, CAN/CSA-C22.2 No. 60950-1
- Included Accessories
- Rack mounting kit, 2 power cords
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 48.3 cm
- 59.7 cm
- 8.8 cm
- 26.3 kg
- Limited warranty - parts - 3 years
- 10 °C
- 35 °C
- 10 - 90%
- Sound Emission
- 67 dB
