HPE StoreEver 1/8 G2 LTO-7 SAS Autoloader
Quicklinx: CRT3WS00 Mfr#: N7P35A
The HPE StoreEver 1/8 G2 Tape Autoloader provides cost-effective, easy-to-install, unattended automated tape storage ideal for archiving and for entry-level or remote office automated data backup. The autoloader combines incredible storage density and features into a compact 1U form factor. Capable of up to 120 TB of compressed capacity in only a 1U form factor, the autoloader is well equipped to offer solutions for data growth. Web-based remote management offers the capability to quickly and easily access, configure, monitor, and troubleshoot the autoloader that will reduce dependencies on local IT staff while allowing multiple sites to be supported centrally. Protect confidential business information with native encryption, ensuring that if a tape is lost or stolen your data is protected from unauthorized access. Proactively monitor utilization, operational performance, as well as life and health information for both the drive and media with HPE TapeAssure.
  • Exceptional Storage Density
    The HPE StoreEver 1/8 G2 Tape Autoloader has up to 240 TB of compressed capacity in only a 1U form factor using an HPE StoreEver LTO-8 Ultrium 30750 tape drive, which is double the capacity of HPE StoreEver LTO-7 Tape Autoloaders.The HPE StoreEver 1/8 G2 Tape Autoloader has up to 300 MB/s native throughput.Long term data archiving with a specified 30 year media shelf life in normal ambient conditions.
  • Easy to Manage and Use
    HPE StoreOpen Standalone is a free downloadable application that extends the LTFS capability to HPE StoreEver 1/8 G2 Tape Autoloader.LTFS provides a self-describing file system on a HPE LTO-8 cartridge, which enables the combined archiving benefits of application independence, transportability and protection from obsolescence.Each autoloader includes one mail slot, two removable 4-slot magazines for bulk loading of media, and a convenient bulk storage unit for moving media offsite.The bar code reader provides faster inventory times and facilitates tracking of media.Access, configure, monitor, and troubleshoot the HPE StoreEver 1/8 G2 Tape Autoloader with the web-based remote management feature reducing the need for remote office IT staff.
  • Additional Features with Software Downloads and Licenses
    HPE StoreEver 1/8 G2 Tape Autoloader has an option to download CVTL for free to manage, monitor and configure multiple tape libraries through a single console.Proactively monitor drive and media utilization, operational performance, life and health information for drive and media with HPE StoreEver TapeAssure Advanced.Offers high level encryption capability with the HPE 1/8 G2 Tape Autoloader and MSL Tape Libraries Encryption Kit.Kits are quickly installed into an LTO-8, LTO-7, LTO-6 or LTO-5 Ultrium Autoloader and maintains up to 100 encryption keys ensuring data privacy to secure confidential information for tape cartridges located on or off site.
HPE StoreEver 1/8 G2 Ultrium 15000 - tape autoloader - LTO Ultrium - SAS-2
Tape autoloader
Recording Standard
LTO Ultrium 7
Enclosure Type
External - 1U
Interface Type
SAS-2
Total Storage Capacity
48 TB (native) / 120 TB (compressed)
Removable Media Capacity
8
Average Media Exchange Time
34 sec
Supported Tape Drives
LTO Ultrium 7
Key Features
Barcode reader, encryption
48 cm x 80.6 cm x 4.4 cm
11.36 kg
Storage Removable
LTO Ultrium
Storage Removable Capacity
6 TB (native) / 15 TB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 6, Ultrium 7
Data Transfer Rate (native)
300 MBps (1.08 TBph)
Data Transfer Rate (compressed)
750 MBps (2.7 TBph)
1-year warranty
Tape autoloader - LTO Ultrium
Recording Standard
LTO Ultrium 7
Enclosure Type
External - 1U
Interface Type
SAS-2
8
34 sec
LTO Ultrium 7
Key Features
Built-in Devices
Led panel
48 cm
80.6 cm
4.4 cm
11.36 kg
Storage Removable
LTO Ultrium
Recording Standard
750 MBps (2.7 TBph)
Buffer Size
1024 MB
1 x SAS 6Gb/s , 1 x (management) - RJ-45 , 1 x USB (management)
6 rubber feet
1 x network cable , 1 x SAS cable - 2 m
Rack Mounting Kit
Optional
MTBF
100,000 hour(s)
MSBF
2,000,000
AES-256, RoHS2
Power supply
80 Watt
Limited warranty - parts - 1 year
5 °C
10 - 80% (non-condensing)
