HPE STORAGEWORKS 1U SAS RACK MOUNT KIT
Quicklinx: 88XGWS00 Mfr#: AE459B
The HP Rack-mount Kits provide a high density, rack-mountable tape drive and RDX removable disk drive solution for both direct-attach SCSI, USB, or SAS backup and archiving applications. The HP 1U Rack-mount Kit supports DAT and LTO Ultrium internal tape drives, and RDX internal removable disk backup systems. The 1U rack-mount kit is available in SCSI, SAS and USB interfaces. With two LTO-6 Ultrium 6250 drives, the 1U SAS enclosure can provide a maximum compressed capacity of 12.5TB with a data transfer rate up to 2.8TB/hr. The HP 3U Rack-mount Kit holds two (2) full-height internal tape drives, four half-height internal tape drives, or a combination of one full height and two half-height tape drives. It is available in both SCSI and SAS interfaces. With four LTO-6 Ultrium 6250 SAS drives this enclosure solution can provide a maximum compressed capacity of 25TB.
  • Space-efficient Way to Rack-mount MSL Tape Drives and RDX Backup Systems
    HPE StoreEver Rack-mount Kit is ideal for customers who have limited space in their rack as it allows for a smaller footprint leaving valuable space for other key components in the data center.The 1U HPE StoreEver Rack-mount Kit allows users to mix a variety of technologies, including LTO Ultrium, as well as RDX removable disk technology by selecting the appropriate cabling.The enclosures support standard internal LTO tape drives and HPE RDX Removable Disk Backup Systems, allowing for drive upgrades when you need additional capacity or want to migrate to a new generation of LTO tape drives or RDX removable disk technology.Provides up to 90 TB of storage capacity (assuming 2.5:1 compression) using two LTO-9 Ultrium 45000 drives or up to 8 TB of storage capacity using two RDX 4 TB removable hard disk drives.Data transfer rates up to 600 MB/s (native) using two LTO-9 Ultrium 45000 drives or up to 360 GB/hour using two RDX removable hard disk drives.
  • Generic Rack-mount Kit Supporting SAS and USB Interfaces for Your Environment
    The HPE StoreEver 1U generic rack-mount kit allows customers to rack-mount SAS-based tape drives and USB-based RDX hard disk drives for industry-first flexibility with the selection of appropriate cabling.
  • Quick and Easy Installation
    In addition to no tools required for installation, the HPE StoreEver Rack-mount Kit provides top access and a removable drive tray for easier access to LTO tape drives and RDX removable hard-disk drives.
HPE StorageWorks SAS Rack-Mount Kit - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 1U
Carbon
42.9 cm x 64.1 cm x 4.3 cm
8.1 kg
LTO-4 Ultrium; LTO-5 Ultrium; ProLiant DL360p Gen8, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special; StorageWorks Rack-Mount Kit Ultrium 1760 Drive; StorageWorks Ultrium 1760; StoreEver LTO-5 Ultrium; Ultrium 448, 920
Storage enclosure
Enclosure Type
Rack-mountable - 1U
Enclosure Colour
Carbon
CPU
No CPU
2 x SAS 6Gb/s
Internal power supply
42.9 cm
64.1 cm
4.3 cm
8.1 kg
5 °C
20 - 80%
HPE LTO-4 Ultrium 1760 , HPE LTO-5 Ultrium 3000, 3000 SAS Internal Tape Drive , HPE ProLiant DL360p Gen8, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special , HPE StorageWorks Rack-Mount Kit Ultrium 1760 Drive , HPE StorageWorks Ultrium 1760 , HPE StoreEver LTO-5 Ultrium 3000 SAS Internal Tape Drive , HPE Ultrium 448, 920
88XG HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge In Stock £35.59
