HPE S/Works D2D4004i Backup System
Quicklinx: 71G4WS00 Mfr#: EH938A
Has unpredictable data growth resulted in management complexity and risk? HP StoreOnce Backup systems with StoreOnce Catalyst software provide a consistent, high-performance scale-out backup architecture that spans the entire enterprise and Federated Catalyst that can reduce management in large environments. You can reduce the amount of backup data you need to store by 95% and choose between powerful dedicated appliances for larger offices and data centers, and flexible virtual appliances for smaller and remote offices. Industry leading backup and restore speeds mean that you can meet shrinking backup windows and recovery SLAs. Plus, with HP StoreOnce as the industry's only federated deduplication technology, you can dedupe anywhere and control the movement of dehydrated data across the enterprise using your backup application. Seamlessly integrating with your current backup applications, StoreOnce Backup provides flexible integration for SAN, Ethernet and virtualized environments.
  • Industry-leading, Scale-out Architecture from Small and Remote Offices to Enterprise Data Centers
    Scale-out architecture allows you to pay as you grow. Choose capacity points available through virtual backup solutions or dedicated appliances that start small and allow you to add in virtual capacity, shelves or nodes.With a range of capacity points to suit all requirements from small remote offices to enterprise data centers with centralized monitoring through HPE StoreOnce Enterprise Manager.For enterprise data centers the HPE StoreOnce 6600 scales from 72 TB to 1,728 TB usable local storage. With Cloud Bank Storage you can scale up to 5,184 TB.For mid-size data centers choose HPE StoreOnce 3520, scale from 7.5-15.5 TB or StoreOnce 3540 scale from 15.5-31.5 TB or StoreOnce 5100 to scale from 36-216 TB or StoreOnce 5500 to scale from 36-864 TB usable. All HPE StoreOnce Systems can triple their effective capacity with Cloud Bank Storage.For small and remote offices choose the HPE StoreOnce VSA virtual appliance, licensed at 4 TB, 10 TB, 32 TB and 50 TB capacity points or the entry-level HPE StoreOnce 3100 for 5.5 TB usable local storage both with 3x the capacity with Cloud Bank Storage.
  • Federated Deduplication Across the Enterprise with a Single Deduplication Technology - StoreOnce
    Deduplicate at the application source, the backup server, the target appliance or directly from HPE 3PAR StoreServ via HPE StoreOnce RMC. Deduplicate where it makes sense for your business, not where technology vendors' limitations mandate, saving time and money.HPE StoreOnce delivers a unified solution for seamless data movement across the enterprise; with cost-effective virtual backup machines ideal for smaller remote offices, high-performance dedicated appliances for larger sites, and highly scalable, powerful systems for your data center.Federated Deduplication is available across the HPE StoreOnce Systems portfolio, including dedicated appliances, virtual backup solutions, and on media servers and application servers with Data Protector, Veritas NetBackup and Backup Exec software via OST, Veeam and BridgeHead software.HPE StoreOnce also supports critical business applications via no cost Catalyst plug-ins for Oracle RMAN, SAP HANA, Microsoft SQL and SAP on Oracle.
  • Backup within your Window and Meet your Restore SLAs with StoreOnce Industry Leading Performance
    A broad range of superior, best-in-class price/performance points to meet the challenges of data growth and shrinking backup windows across the enterprise.Industry leading performance of up to 184 TB/hour at the high-end, with HPE StoreOnce 6600 and HPE StoreOnce Catalyst.Up to 37.7 TB/hour with HPE StoreOnce 5500, or up to 26.7 TB/hour with HPE StoreOnce 5100, or up to 12.7 TB/hour with HPE StoreOnce 3540 and HPE StoreOnce Catalyst.Up to 12.7 TB/hour with HPE StoreOnce 3520 or up to 6.4 TB/hour with HPE StoreOnce 3100 and up to 6 TB/hour for HPE StoreOnce VSA with HPE StoreOnce Catalyst.
  • Automated, Efficient Backup and Disaster Recovery Operations with StoreOnce Catalyst
    Manage backup and Disaster Recovery operations from a single pane of glass with StoreOnce Catalyst Backup and copy is supported over Ethernet and Fibre Channel.Implement disaster recovery plans that were not previously feasible due to lack of multi-site capabilities, cost of bandwidth and time.One-to-many disaster recovery moves data simultaneously from one site to many sites. Cascaded disaster recovery moves data sequentially from one site to any number of other sites.Alerting and trending in Reporting Central to enable centralized backup capacity management.
HPE StorageWorks D2D4004i Backup System - NAS server - 4.5 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
4.5 TB
44.8 cm x 69.9 cm x 8.8 cm
25.9 kg ()
Storage Controller
SATA RAID 6
Hard Drive
6 x 750 GB
Network adapter 100Mb LAN, 1GbE
1-year warranty
ProLiant DL160se G6, DL165 G5, DL180 G5, DL185 G5, DL320 G5p, DL360 G5, DL360 G7, DL365 G5, DL370 G6, DL380 G7, DL385 G5, DL385 G5p, DL385 G7, DL785 G5, ML115 G5, ML310 G5, ML350 G5, ML350 G6, ML370 G5, ML370 G6
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
4.5 TB
44.8 cm
69.9 cm
8.8 cm
25.9 kg ()
Storage Controller
SATA
RAID Level
RAID 6
Hard Drive
HDD
6 x 750 GB
Spindle Speed
7200 rpm
Network adapter
100Mb LAN, 1GbE
2 x network cable - 3 m , 2 x power cable
Internal power supply
Power Provided
750 Watt
Software Included
Drivers & Utilities
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
10 °C
35 °C
10 - 90%
HPE ProLiant DL160se G6, DL165 G5 Special Server, DL180 G5 Special Server, DL185 G5 Special Server, DL320 G5p, DL360 G5 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL365 G5 Base, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL385 G5 Entry, DL385 G5p Base, DL385 G5p High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL785 G5, ML115 G5, ML310 G5, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G5, ML370 G6, ML370 G6 Base, ML370 G6 Entry
