HPE OfficeConnect OC20 (RW) Radio Access Point
Quicklinx: D0SSWS00 Mfr#: JZ074A
  • IEEE 802.11n
HPE OfficeConnect OC20 dual radio 802.11ac access point series offers small businesses an intuitive and cost effective wireless solution that is simple to set-up and manage without technical expertise. OC20 delivers Gigabit speeds and reliable connectivity to handle today's business critical applications and a separate guest network with social media log-ins. Built-in application filtering protects your network from on-line threats.
HPE OfficeConnect solutions help you do more with less—enabling you to share resources and collaborate without the complexity of setting up an enterprise-grade network. OfficeConnect products are simple to manage, affordable and highly reliable for small businesses with no dedicated IT expertise and resources. Whether you’re just starting out or planning to expand your business, OfficeConnect offers a wide range of wired and wireless solutions to support your small business needs at each stage of your growth.
An intuitive mobile app for simple network set-up and management
Setting up a wireless network has never been easier with the OfficeConnect mobile app. It automatically detects the OfficeConnect access point—all you need to do is create a network name and password and your network is ready to go. When you’re ready to expand new APs automatically join the network, with no set up required. You can centrally monitor and manage up to eight APs—making ongoing network updates and maintenance a snap.
In just a few steps you can create separate employee and guest networks. Choose from open guest access, simple password sign-in or Facebook Wi-Fi log-ins. You can set up a network access schedule for guests by restricting access to specific days and hours of the week. You can even include your logo for your log-in page for a branded Wi-Fi experience.
  • Fast Reliable Connectivity
    The HPE OfficeConnect OC20 Dual Radio 802.11ac Access Point Series supports speeds up to 1.3 Gbps to easily handle your mobile devices and applications.Smart Air software intelligently optimizes wireless coverage and performance and automatically connects you to the fastest access point for a superior user experience.A captive portal offers easy guest onboarding using Facebook Wi-Fi.
  • Easy to Install, Simple to Manage
    The HPE OfficeConnect Mobile OC20 Dual Radio 802.11ac Access Point Series mobile application offers a simple, intuitive and quick network set-up for non-technical users.Centrally manage up to eight APs using clustering making ongoing network changes and maintenance a snap.Simplify network maintenance and troubleshooting with a quick network health dashboard and monitor your network remotely, no matter where you might be.
  • Protect Your Business with Enhanced Security
    The HPE OfficeConnect OC20 Dual Radio 802.11ac Access Point Series integrated Web content filtering provides comprehensive protection against on-line threats.Keep your wireless network traffic safe with WPA2 and advanced encryption.
HPE OfficeConnect OC20 (RW) - radio access point - Wi-Fi 5
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Concurrent data rate (5 GHz): 867 Mbps , Concurrent data rate (2.4 GHz): 400 Mbps , Peak data rate: 1.3 Gbps
Wireless clients per Wi-Fi radio: 100
2 x ceiling mounting clip
Power Over Ethernet (PoE) Supported
PoE
14.986 cm x 4.064 cm x 14.986 cm
380 g
3-year warranty
Radio access point
Ruggedized Design
Indoor
14.986 cm
4.064 cm
14.986 cm
380 g
External
Wireless
Data Transfer Rate
867 Mbps
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
System, status
Auto-uplink (auto MDI/MDI-X), reset button, 2T2R MIMO technology, Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Space Time Blocking Code (STBC), MU-MIMO technology, Energy-Efficient Ethernet (EEE)
Encryption Algorithm
WPA2
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Omni-directional
Gain Level
6.6 dBi
1 x 1000Base-T - RJ-45
EN 60950, IEC 60950, UL 60950, CB, UL 2043, FCC, EN 60601-1-2, cTUVus, EN 300 328, EN 301 489, EN 60601-1-1, LVD 2014/35/EU, EN 301 893, Directive 2014/53/EU
PoE
12.3 watt
Limited warranty - advance parts replacement - 3 years
50 °C
5 - 95% (non-condensing)
D0SS Aruba Network Device Wall / Ceiling Mount Kit - White In Stock £10.98
