HPE MSA 50 1U SAS Enclosure
Quicklinx: 442NWS00 Mfr#: 364430-B21
The HP Modular Smart Array 50 Enclosure MSA50 is a 1U Serial Attach SCSI(SAS) disk drive storage enclosure supporting Small Form Factor (SFF) SAS or Serial ATA (SATA) drives. This enclosure delivers industry-leading data performance, availability, storage density, and upgradeability to meet customers' demanding and growing storage needs. The all new SFF drive carrier is designed to support the new Universal form factor hard drive in either SAS, SAS MDL or SATA. This new form factor provides optimized performance per U of space while delivering unparalleled power consumption. The MSA50 enclosure supports direct attach storage to HP ProLiant and Integrity Servers. The MSA50 supports the cascading of shelves in a 1+1 configuration to allow a maximum of 20 SFF drives in a 2U configuration attached to a single controller port. This single controller port incorporates four lanes for a total max throughput of 12Gb/s for SAS.
  • Efficient storage solution
    The HPE StorageWorks Modular Smart Array 50 offers a compact and efficient storage solution, featuring a 1.4 TB max supported capacity within a 2.5" SFF hot-swap design. This allows for easy expansion and maintenance, ensuring your data storage needs are met with reliability.
  • Enhanced reliability
    Equipped with dual internal power supplies and a power redundancy scheme of 1+1, the storage enclosure ensures continuous operation. The hot-plug capability further enhances system reliability, minimizing downtime and maintaining business continuity.
  • Optimal environmental adaptability
    Designed to operate within a wide range of temperatures from 10°C to 35°C and a humidity range of 10 - 90%, the HPE StorageWorks Modular Smart Array 50 is built to withstand various environmental conditions, ensuring consistent performance.
HPE StorageWorks Modular Smart Array 50 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 1U
Max Supported Capacity
1.4 TB
0 (installed) / 10 (max)
Supported Drives
SATA-150 / SAS
Asia Pacific, North America, EMEA
Built-in Devices
Led panel
Hard Drive
0 HDD - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
59.2 cm x 83.2 cm x 30.2 cm
9.1 kg
3-year warranty
ProLiant DL140 G2, DL160 G6, DL165 G5, DL165 G6, DL170h G6, DL180 G5, DL180 G6, DL185 G5, DL360 G5, DL365 G5, DL370 G6, DL380 G5, DL380 G6, DL385 G2, DL385 G5, DL385 G5p, DL385 G6, DL580 G5, DL585 G6, DL785 G5, DL785 G6, DL980 G7, ML330 G6, ML350 G4p, ML350 G5, ML350 G6, ML370 G5, ML370 G6, ML570 G4
Storage enclosure
Enclosure Type
Rack-mountable - 1U
Chassis
Built-in Devices
Led panel
0
Supported Devices / Modules Qty
10
Supported Drives
SATA-150 / SAS
Storage
1.4 TB
CPU
No CPU
Hard Drive
HDD - hot-swap
0
Expansion Bays
10 (total) / 10 (free) x hot-swap - 2.5" SFF
1 x SAS - 4 x InfiniBand (SFF-8470)
1 x SAS cable - 2 m
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
59.2 cm
83.2 cm
30.2 cm
9.1 kg
Limited warranty - parts - 3 years
10 °C
35 °C
10 - 90%
HPE ProLiant DL140 G2, DL160 G6, DL165 G5 Special Server, DL165 G6, DL170h G6, DL180 G5 Special Server, DL180 G6, DL180 G6 Special Server, DL185 G5 Special Server, DL320 G3, DL360 G4, DL360 G4p, DL360 G5, DL360 G5 Base, DL360 G5 Entry, DL360 G5 Performance, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380 G4, DL380 G4 High Performance, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Performance, DL380 G5 Storage Server 2TB SATA Model, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL385, DL385 G2 Base, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p Base, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL580 G2, DL580 G3, DL580 G5 Highly Serviceable Tower, DL585, DL585 G6, DL585 G6 Base, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance, DL980 G7, ML310 G2, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G4, ML350 G4p, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G4, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, ML570 G2, ML570 G3, ML570 G4, ML570 G4 High Performance
