HPE MSA 2050 SFF Disk Enclosure
Quicklinx: F8MKWS00 Mfr#: Q1J07A
Looking for affordable, high-performance shared storage? The HPE MSA 2050 SAN Storage is a flash ready system designed for affordable application acceleration ideal for small and remote office deployments. Don't let the low cost fool you, it gives you the combination of simplicity, flexibility to grow now, and advanced features you may not expect in an entry-priced array. Start small and scale as needed with any combination of solid state disks (SSD), high-performance enterprise, or lower-cost midline SAS-based drives.
  • Energy efficient
    With ENERGY STAR certification, this storage enclosure ensures efficient power usage, reducing operational costs and supporting eco-friendly initiatives.
  • Flexible storage solution
    Supports up to 24 2.5" SFF drives, offering a scalable and flexible solution for growing storage needs. Its Serial Attached SCSI 3 interface ensures high-speed data transfer and compatibility with a wide range of devices.
  • Reliable power
    Equipped with dual internal power supplies, this enclosure provides redundancy and reliability, ensuring continuous operation and data availability even in the event of a power supply failure.
HPE Modular Smart Array 2050 SFF Disk Enclosure - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
0 (installed) / 24 (max)
Supported Drives
SAS-3
AC 120/230 V - 50/60 Hz
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
24
Supported Drives
SAS-3
CPU
No CPU
Expansion Bays
24 (total) / 24 (free) - 2.5" SFF
2 x SAS 12Gb/s
2 x mini SAS cable - 50 cm
ENERGY STAR Certified
2 x internal power supply
Max Supported Qty
2
Limited warranty - parts - 3 years
