HPE MSA 2050 SAS DC LFF Storage
Quicklinx: F8MLWS00 Mfr#: Q1J28A
Looking for affordable, high-performance shared storage? The HPE MSA 2050 SAN Storage is a flash ready system designed for affordable application acceleration ideal for small and remote office deployments. Don't let the low cost fool you, it gives you the combination of simplicity, flexibility to grow now, and advanced features you may not expect in an entry-priced array. Start small and scale as needed with any combination of solid state disks (SSD), high-performance enterprise, or lower-cost midline SAS-based drives. HPE MSA 2050 SAN Storage has been the industry-leading entry storage Fibre Channel (FC) platform for the past eight years, with nearly 500,000 systems sold worldwide . Delivers 2x higher performance than the previous generation at the same price, delivering in excess of 200,000 IOPS. It's seriously simple and affordable flash-ready storage to help you get the most performance for the lowest cost.
  • Accelerates Applications Affordably
    The HPE MSA 2050 SAN Storage performs at 200,000 IOPS delivering affordable application acceleration for small to medium-sized businesses both local and remote.Flexible base model delivers 2x more performance than previous generation HPE MSA 2040 SAN Storage for the same price.
  • Advanced Data Services With No Experience Required
    The HPE MSA 2050 SAN Storage is easy to install, easy to use, easy to maintain, no previous storage expertise required.Automated tiering dynamically responds to workload changes, so you don't have to.
  • Keep Your Business Running with Expanded Data Protection Features
    The HPE MSA 2050 SAN Storage delivers updated virtualized snapshot technology making data protection and instant recovery a snap.Remote replication with Fibre Channel (FC) and iSCSI supports an affordable disaster recovery solution.
  • Grow Flexibly Now and Into the Future
    The HPE MSA 2050 SAN Storage supports data-in-place upgrades protecting drive investments and reduces data migrations.Start small and scale as needed with any combination of Solid State Drives (SSDs), enterprise or midline SAS disk drives.
HPE Modular Smart Array 2050 SAN Dual Controller LFF Storage - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
120 TB
SAS 12Gb/s
Maximum LUNs
512
0 (installed) / 12 (max)
Supported Drives
SAS-3
Storage Controller
RAID (SAS 12Gb/s) - RAID 1, 5, 6, 10
Storage Controller Quantity
2
Hard Drive
No HDD
HP-UX, Red Hat Linux, Apple MacOS X, Microsoft Windows Server 2016, Microsoft Windows Hyper-V Server
AC 120/230 V - 50/60 Hz
Power Redundancy
44.7 cm x 57.2 cm x 8.9 cm
18.4 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SAS-3
Storage
120 TB
HDD Array External Interface
SAS 12Gb/s
Maximum LUNs
512
CPU
No CPU
Storage Controller
RAID (SAS-3)
Installed Qty
2
Interface Type
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Cache / Buffer Size (Max)
8 GB
RAID Level
RAID 1, RAID 5, RAID 6, RAID 10
Storage Controller (2nd)
Installed Qty
2
Hard Drive
No HDD
Expansion Bays
12 (total) / 12 (free) - 3.5" LFF
8 x SAS 12Gb/s , 2 x mini-USB 2.0 (management) , 2 x Ethernet 1000Base-T (management) - RJ-45 , 2 x SAS
Systems Insight Manager (SIM)
CISPR 22 Class A, CISPR 24, EN55022, GS, EN55024, CCC, FCC Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, RoHS, CAN/CSA C22.2 No. 60950-1-03, VCCI Class A, KN24, KN22 Class A, CNS 13438 Class A, ICES-003:2004 Class A, EN61000-3-3, EN61000-3-2
ENERGY STAR Certified
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
344 watt
44.7 cm
57.2 cm
8.9 cm
18.4 kg
Limited warranty - parts - 3 years
5 °C
10 - 90% (non-condensing)
Sound Emission
55 dBA
