Looking for affordable, high-performance shared storage? The HPE MSA 2050 SAN Storage is a flash ready system designed for affordable application acceleration ideal for small and remote office deployments. Don't let the low cost fool you, it gives you the combination of simplicity, flexibility to grow now, and advanced features you may not expect in an entry-priced array. Start small and scale as needed with any combination of solid state disks (SSD), high-performance enterprise, or lower-cost midline SAS-based drives. HPE MSA 2050 SAN Storage has been the industry-leading entry storage Fibre Channel (FC) platform for the past eight years, with nearly 500,000 systems sold worldwide . Delivers 2x higher performance than the previous generation at the same price, delivering in excess of 200,000 IOPS. It's seriously simple and affordable flash-ready storage to help you get the most performance for the lowest cost.
Accelerates Applications Affordably
The HPE MSA 2050 SAN Storage performs at 200,000 IOPS delivering affordable application acceleration for small to medium-sized businesses both local and remote.Flexible base model delivers 2x more performance than previous generation HPE MSA 2040 SAN Storage for the same price. -
Advanced Data Services With No Experience Required
The HPE MSA 2050 SAN Storage is easy to install, easy to use, easy to maintain, no previous storage expertise required.Automated tiering dynamically responds to workload changes, so you don't have to. -
Keep Your Business Running with Expanded Data Protection Features
The HPE MSA 2050 SAN Storage delivers updated virtualized snapshot technology making data protection and instant recovery a snap.Remote replication with Fibre Channel (FC) and iSCSI supports an affordable disaster recovery solution. -
Grow Flexibly Now and Into the Future
The HPE MSA 2050 SAN Storage supports data-in-place upgrades protecting drive investments and reduces data migrations.Start small and scale as needed with any combination of Solid State Drives (SSDs), enterprise or midline SAS disk drives.
 - HPE Modular Smart Array 2050 SAN Dual Controller SFF Storage - hard drive array
 - Hard drive array
- Enclosure Type
 - Rack-mountable - 2U
- Installed Devices / Modules Qty
 - 0 (installed) / 24 (max)
- Supported Drives
 - SAS-2
- Storage Controller
 - RAID (SAS 6Gb/s) - RAID 1, 5, 6, 10
- Storage Controller Quantity
 - 2
- OS Required
 - HP-UX, SuSe Linux, Red Hat Enterprise Linux, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016
- Power
 - AC 120/230 V - 50/60 Hz
- Power Redundancy
 - 44.7 cm x 57.2 cm x 8.9 cm
 - 18.4 kg
- Environmental Standards
 - ENERGY STAR Qualified
 - 3-year warranty
 - Hard drive array
- Enclosure Type
Chassis
 - 0
- Supported Devices / Modules Qty
 - 24
- Supported Drives
 - SAS-2
- CPU
 - No CPU
Storage Controller
 - RAID
- Installed Qty
 - 2
- Interface Type
 - SAS 6Gb/s
- Data Transfer Rate
 - 600 MBps
- Cache / Buffer Size (Max)
 - 8 GB
- RAID Level
 - RAID 1, RAID 5, RAID 6, RAID 10
Storage Controller (2nd)
- Installed Qty
 - 2
- Expansion Bays
 - 24 (total) / 24 (free) - 2.5" SFF
 - 2 x mini-USB 2.0 (management) , 2 x management - RJ-45 , 2 x SAS - RJ-45
- OS Required
 - Systems Insight Manager (SIM)
 - CISPR 22 Class A, CISPR 24, EN55022, GS, EN55024, CCC, FCC Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, RoHS, CAN/CSA C22.2 No. 60950-1-03, VCCI Class A, KN24, KN22 Class A, CNS 13438 Class A, ICES-003:2004 Class A, EN61000-3-3, EN61000-3-2
- ENERGY STAR Certified
- Power Device
 - 2 x internal power supply - hot-plug
- Max Supported Qty
 - 2
- Power Redundancy
- Power Redundancy Scheme
 - 1+1
- Voltage Required
 - 390 Watt
 - 44.7 cm
 - 57.2 cm
 - 8.9 cm
 - 18.4 kg
 - Limited warranty - parts - 3 years
 - 5 °C
 - 40 °C
 - 10 - 90% (non-condensing)
- Sound Emission
 - 55 dBA
