HP 1905 Switch Series devices are smart-managed fixed-configuration Fast Ethernet Layer 2 switches designed for small businesses looking for key features in an easy-to-administer, low-cost solution. Series models include: 24- and 48-port non-PoE switches, 8- and 24-port PoE Fast Ethernet switches. These smart-managed switches come preconfigured for fast and easy installation, yet allow network operation to be enhanced using an intuitive Web-based management interface. Advanced security and quality-of-service features create a voice-ready network. HP 1905 series switches are solidly built for business operation, and are designed for high reliability, long life, low power consumption, and low total cost of ownership. The HP 1905 switches come with a 3-year warranty, covering unit, fans, and power adapters or power supplies.
Quality of Service (QoS)
Traffic prioritization (IEEE 802.1p): allows real-time traffic classification mapped to four hardware queues per port. -
Management
Simple Web management: easy device management even by nontechnical users enabled by intuitive Web GUI.Secure web GUI: provides a secure, easy-to-use graphical interface for configuring the module via HTTPS.SNMPv1, v2c: devices can be discovered and monitored from an SNMP management station.Port mirroring: allows traffic to be mirrored on any port or a network analyzer to assist with diagnostics or detecting network attacks.IEEE 802.1AB Link Layer Discovery Protocol (LLDP): automated device discovery protocol for easy mapping by network management applications. -
Auto-MDIX: automatically adjusts for straight-through or crossover cables on all ports.Front-panel LEDs: provide an at-a-glance view of status, activity, speed, and full-duplex operation.Flow control: helps ensure reliable communications during full-duplex operation.Small Form-Factor Pluggable (SFP) slots: allow for fiber connectivity.Cable diagnostics: remotely detect cable issues using a browser-based tool.
- HPE 1905-8-PoE Switch - switch - 8 ports - Managed - rack-mountable
- Switch - 8 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100 (PoE) + 1 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- Routing Protocol
- IGMP
- Remote Management Protocol
- RMON 2, SNMP, HTTP
- Flow control, Layer 2 switching, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, manageable, STP support, RSTP support, ACL support, QoS
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 33 cm x 20.3 cm x 4.3 cm
- 2 kg
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- PoE
- Routing Protocol
- IGMP
- Encryption Algorithm
- SSL
- Authentication Method
- RADIUS
- Processor
- 1: 133 MHz
- RAM
- 32 MB SDRAM
- Flash Memory
- 4 MB Flash
- 8 x 100Base-TX RJ-45 PoE , 1 x 1000Base-T RJ-45 , 1 x console RJ-45 management , 1 x SFP (mini-GBIC)
- Voltage Required
- Rack Mounting Kit
- Included
- VCCI, CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, UL 60950, ICES-003 Class A, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, FCC Part 15 A
- 33 cm
- 20.3 cm
- 4.3 cm
- 2 kg
- 0 °C
- 45 °C
- 10 - 90%
