HPE HP UPS R1500 G3 XR 1500VA 1000W
Quicklinx: 800CWS00 Mfr#: AF471A
Looking for cost-effective power protection for your small office environments? HP Line Interactive Single Phase Uninterruptible Power System (UPS) solutions range from tower-based systems designed to safeguard tower servers and small office equipment, to rack-based systems that can protect a full rack of servers. Standard features include intuitive front panel displays for local management, hot-swappable battery modules, and HP Enhance Battery Management (EBM) that help to extend the service-life of your batteries. HP Power Protection, a power management software application that ships with each model, combined with a UPS Network Module, optional on some models, enables you to remotely monitor and manage your UPS through HP Systems Insight Manager or via a standard web browser. Backed by a 3-year limited warranty, HP's exclusive 30-day Battery Pre-Failure Warning provides notification of an impending battery failure and free battery replacement while under the warranty.
  • Tower UPS Models Provide Power Protection and Management Optimized for Smaller IT Environments
    HP Line Interactive Single Phase Uninterruptible Power System Tower models lower your power protection cost by providing up to eight (8) power outlets per UPS, allowing you to safeguard your IT and office equipment.Standard features include an intuitive front panel display, Enhanced Battery Management (EBM), Network Transient Protection, and serial and USB ports for data exchange with the host computer.Support hot-swappable battery packs that allow you to safely install a new battery without ever powering down connected computer equipment.Includes (at no additional cost) HP Power Manager software that provides the flexibility to monitor power conditions and control the HP UPS locally or remotely.Backed by a 3-year limited warranty and an exclusive 30-day Battery Pre-Failure Warning providing notification from HP Power Manager software of an impending battery failure and free replacement while under the warranty.
  • Flexible Rack/Tower Models Deliver Cost-Effective Power Protection Inside and Outside of the IT Rack
    HP Line Interactive Single Phase Uninterruptible Power System Rack/Tower (R/T) models can be used in a traditional rackmount environment or converted to a tower UPS to support tower servers and other equipment outside of an IT rack.Support up to four (4) Extended Runtime Modules (ERM) to increase battery run time during a power outage.Standard features include an enhanced front panel display, HP Enhanced Battery Management (EBM) to easily manage and extend the service life of your batteries, and hot-swappable batteries that can be serviced while the UPS is in operation.HP Power Protection software (included) and an UPS Network Module (optional) enable you to monitor and manage power through HP Systems Insight Manager and other SNMP management programs or via a standard web browser.Backed by a 3-year limited warranty and an exclusive 30-day Battery Pre-Failure Warning providing notification from HP Power Manager software of an impending battery failure and free replacement while under the warranty.
  • Ultra-Dense Rack UPS Models Scale from Small to Enterprise IT Environments
    HP Line Interactive Single Phase Uninterruptible Power System Rackmount models provide from 1.5kVA (R1500 G4) up to 7.2kVA (R7000) of output power in as little as 4U of rack space.Support up to four (4) Extended Runtime Modules (ERM) to increase battery run time during a power outage (R5000 and R7000 only).Support hot-swappable battery packs that allow you to safely install a new battery without ever powering down connected computer equipment.The R5000 and R7000 include both HP Power Protection software and an UPS Network Module that enable you to monitor and manage power through HP Systems Insight Manager and other SNMP management programs or via a standard web browser (UPS Network Module optional on R1500 G4).Backed by a 3-year limited warranty and an exclusive 30-day Battery Pre-Failure Warning providing notification from HP Power Manager software of an impending battery failure and free replacement while under the warranty.
HPE UPS R1500 G3 - UPS - 1 kW - 1500 VA
UPS - rack-mountable
Rack Size
1U
22.9 kg
Input Voltage
AC 220/230/240 V
Output Voltage
+ 6% / - 10%
Power Capacity
1 kW / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Plug-in module
Run Time (Up To)
5 min at full load
RS-232, USB
44.5 cm x 61 cm x 4.4 cm
3-year warranty
Apollo 4510 Gen9; ProLiant DL120 G7, DL160 Gen8, DL165 G7, DL360 G7, DL360e Gen8, DL360p Gen8, DL380 G7, DL380p Gen8, DL385p Gen8, ML310e Gen8, ML350e Gen8, SL210t Gen8, SL230s Gen8, SL270s Gen8; Rack
Battery Enclosure Type
Plug-in module
Height (Rack Units)
1U
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Margin
+ 20% / - 20%
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
+ 6% / - 10%
Power Capacity
1 kW / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Max Spike Current
6500 A
Lead Acid
Run Time (Up To)
5 min at full load , 8 min at 80% load , 17 min at half load , 58 min at 20% load
Recharge Time
24 hours
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB)
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Serial cable - external - 1.8 m , USB cable - external - 1.8 m
Rack Mounting Kit
Included
LED indicators, hot-swappable batteries
FCC Class A certified, UL, C-Tick, BSMI, GOST, ANSI C62.41, cUL, EN 60950, GS, UL 1778, VCCI Class A ITE, CSA 22.2 No. 950, CISPR 22, CB, EN 50091-2, CSA C22.2 No. 107.1, EN 50091-1, FCC CFR47 Part 15, WEEE, ICES, IEC 801-2, IEC 801-5, IEC 801-4, IEC 801-3
Software Included
HP Power Protector (free download)
Limited warranty - 3 years
10 °C
5 - 95%
Sound Emission
46 dB
44.5 cm
61 cm
4.4 cm
22.9 kg
Shipping Width
81.3 cm
Shipping Depth
68 cm
Shipping Height
29.2 cm
Shipping Weight
34.5 kg
HPE Apollo 4510 Gen9 , HPE ProLiant DL120 G7, DL160 Gen8, DL160 Gen8 Entry, DL160 Gen8 Performance, DL165 G7 Base, DL360 G7, DL360e Gen8, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL380 G7 Special Server, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, SL210t Gen8 1U Node, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray , HPE Rack
