HPE HP M330 802.11ac Access Point
Quicklinx: BVDFWS00 Mfr#: JL063A
  • IEEE 802.11n
The HPE M330 Dual Radio 802.11ac Access Point Series (AP) delivers high-performance wireless networking for small businesses. They support standalone operations or "clustering" of up to 16 APs. These 3x3:3 MIMO technology devices offer simultaneous 1.3 Gbps IEEE 802.11ac performance and up to 450 Mbps IEEE 802.11n to support increasing device density and bandwidth-intensive applications such as video. Clustering technology simplifies administration and advanced features such as business-class security and uninterrupted wireless client roaming provide a better user experience.
HPE M330 (WW) - radio access point - Wi-Fi 5
Radio access point
External - indoor
1 x 800 MHz
RAM
256 MB
Flash Memory
128 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 8 , VLANs supported: 8
Power Over Ethernet (PoE) Supported
PoE
15.57 cm x 4.01 cm x 20.88 cm
1.23 kg
Radio access point
Ruggedized Design
Indoor
15.57 cm
4.01 cm
20.88 cm
1.23 kg
Processor / Memory / Storage
Processors Installed
1 x 800 MHz
RAM
256 MB SDRAM
Flash Memory
128 MB
External
Wireless
Data Transfer Rate
1.3 Gbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTPS, CLI
Communication Mode
Half-duplex, full-duplex
Frequency Band
2.4 GHz, 5 GHz
Auto-uplink (auto MDI/MDI-X), IPv6 support, Wireless Distribution System (WDS) support, MIMO technology, Spanning Tree Protocol (STP) support, IPv4 support
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, SSL, TKIP, WPA, WPA2
Authentication Method
Secure Shell (SSH), RADIUS, Secure Shell v.2 (SSH2)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
6
Directivity
Omni-directional
1 x 1000Base-T - RJ-45
EN55022 Class B, ICES-003 Class B, FCC Part 15 B, FCC Part 15.247, RSS-210, RSS-102, MIC, UL 60950-1, IEC 60950-1, KCC, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, KCC Class A, iDA, EN 300 328, FCC OET Bulletin 65c, FCC CFR47 Part 2, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
PoE
13 Watt
15 - 80% (non-condensing)
BVDF C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
