Your basket is empty
HPE HP 300GB SAS 600Mbps 15000rpm Dual Port Hot-Swap HDD
Quicklinx: 7R72WS00 Mfr#: 516824-B21
Type: Hard drive
Controller Type: Serial Attached SCSI
£304.53 ex VAT
£365.43 inc VAT
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HP SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HP Smart Carrier, HP Standard Hot Plug Carrier and HP Non-hot Plug Carrier. HP SAS Hard Drives are available in a 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage where performance, reliability and data integrity are crucial.
HPE Dual Port Enterprise - hard drive - 300 GB - SAS 6Gb/s
Hard drive - internal
300 GB
3.5" x 1/3H
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
15000 rpm
11.7 cm x 18.9 cm x 2.6 cm
3 years warranty
ProLiant DL160 G6, DL160 G6 Special Server, ML110 G6, ML110 G6 Special Server, ML110 G7, ML150 G6, ML330 G6
300 GB
3.5" x 1/3H
SAS 6Gb/s
11.7 cm
18.9 cm
2.6 cm
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
3.5 ms (average) / 6.8 ms (max)
Track-to-Track Seek Time
0.2 ms
Spindle Speed
15000 rpm
Expansion & Connectivity
2 x SAS 6Gb/s
Compatible Bay
3.5" x 1/3H
Limited warranty - 3 years
10 °C
35 °C
HPE ProLiant DL160 G6, DL160 G6 Special Server, ML110 G6, ML110 G6 Special Server, ML110 G7, ML150 G6, ML330 G6
Type: Hard drive
Brand: HPE
Price Range Ex VAT: 300 - 500
