HP E4210G Switch Series are entry-level Gigabit Ethernet LAN switches with enterprise-class quality of service (QoS), security, and management features, delivering high value for network administrators looking for an economical edge device. Available Power over Ethernet (PoE) models are ideal for voice over IP and wireless networking installations, while non-PoE models are also available for simple port expansion. Dual-personality ports allow flexibility, including the ability to add 10 Gigabit Ethernet capability. Setting them apart from lower-end devices, the series switches support an industry-standard command-line interface, Web-based administration, and SNMP management. In addition, they support Intelligent Resilient Framework (IRF) stacking of up to four units.
Secure web GUI
Provides a secure, easy-to-use graphical interface for configuring the module via http. -
Command-line interface
Provides a secure, easy-to-use command-line interface for configuring the module via SSH or a switch console; provides direct real-time session visibility. -
Remote monitoring
Provides advanced monitoring and reporting capabilities for statistics, history, alarms, and events. -
Full-featured console
Provides complete control of the switch with a familiar command-line interface. -
Web interface
Allows configuration of the switch from any web browser on the network. -
Multiple configuration files
Allow multiple configuration files to be stored to flash image.
- HPE 4210-24G Switch - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L4 - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 4 x shared SFP
- MAC Address Table Size
- 16K entries
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTPS, FTP, TFTP, SSH-2
- Full duplex capability, routing, Layer 3 switching, Layer 2 switching, auto-negotiation, BOOTP support, ARP support, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, store and forward, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 44.2 cm x 30 cm x 4.3 cm
- 4 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 16K entries
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- MD5, TLS, PEAP
- Authentication Method
- RADIUS, PAP, CHAP, Secure Shell v.2 (SSH2)
- Processor
- X Broadcom BCM5836: 264 MHz
- RAM
- 64 MB
- Flash Memory
- 16 MB Flash
- Status Indicators
- Port status, power
- 24 x 1000Base-T RJ-45 , 1 x console RJ-45 management , 4 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Rack Mounting Kit
- Included
- CISPR 22 Class A, IEC 61000-3-2, IEC 61000-3-3, VCCI Class A ITE, EN55024, EN55022 Class A, CSA 22.2 No. 60950, ICES-003 Class A, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A
- 44.2 cm
- 30 cm
- 4.3 cm
- 4 kg
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 95% (non-condensing)
