HPE 96W Smart Storage Battery - battery
Quicklinx: BZ5FWS00 Mfr#: 727258-B21
  • Enhanced efficiency
    The 96 W Smart Storage battery significantly boosts the efficiency of your storage solutions, ensuring reliable power backup and smooth operation.
  • Reliable performance
    Designed by Hewlett Packard Enterprise, this storage battery is built for consistent, reliable performance, making it an essential component for your data management needs.
HPE 96W Smart Storage - battery
450 g
ProLiant ML30 Gen9 Entry, ML30 Gen9 Solution
Power cable 145 mm
450 g
HPE ProLiant ML30 Gen9 Entry, ML30 Gen9 Solution
