Power and charge your notebook or tablet from its USB-C port with the HP 45W USB-C AC Adapter.
Simple to use
Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet. -
World-class support
Rest easy with a One-year limited warranty.
 - HP - power adapter - 45 Watt
 - Power adapter - external
- Localisation
 - English / United Kingdom
- Input Voltage
 - AC 115/230 V
- Output Voltage
 - 5 / 12 / 15 V
- Power Capacity
 - 45 Watt
- Output connectors
 - 1 x 24 pin USB-C
 - 6.6 cm x 2.85 cm x 6.6 cm
 - 1-year warranty
- Designed For
 - Chromebook 13 G1; Elite x2 1012 G1, 1012 G2; EliteBook Folio G1; MX12 Retail Solution; Pro x2 612 G2; ProBook 440 G4 Notebook, 440 G6 Notebook, 450 G6 Notebook, 455 G4 Notebook; Spectre Pro 13 G1; x2 210 G2
- Localisation
- Input Voltage
 - AC 115/230 V
- Frequency Required
 - 47 - 63 Hz
- Power Output Connectors Details
 - 1 x 24 pin USB-C
- Output Voltage
 - 5 / 12 / 15 V
- Max Electric Current
 - 5 A
- Power Capacity
 - 45 Watt
 - FCC Class B certified, NORDIC, IEC 60950, UL 60950, EN55022 Class B, CCC, EMC, NOM-1-NYCE
 - Limited warranty - 1 year
 - 0 °C
 - 35 °C
 - 0 - 95% (non-condensing)
 - 6.6 cm
 - 2.85 cm
 - 6.6 cm
- Designed For
 - HP Chromebook 13 G1 , HP Elite x2 1012 G1, 1012 G2 , HP EliteBook Folio G1 , HP MX12 Retail Solution , HP Pro x2 612 G2 , HP ProBook 440 G4 Notebook, 440 G6 Notebook, 450 G6 Notebook, 455 G4 Notebook , HP Spectre Pro 13 G1 , HP x2 210 G2
