HPE HP 10-Bay Battery Charger
Quicklinx: 9RC1WS00 Mfr#: H2W28AA
Device Type: Laptop
£698.29 ex VAT
£837.94 inc VAT
Smart design allows you to charge up ten batteries from select HP 2011 and 2012 Business Notebooks Batteries simultaneously.
LEDs on the face of the charger indicate that the unit is powered and help you monitor individual battery charging status.
HP 10-Bay Battery Charger - battery charger
Battery charger - external
5 kg
Batteries Qty
10 (supported)
55.5 cm x 22.5 cm x 17 cm
1-year warranty
HP CC06XL, CC09, MT06 Mini Battery, SX09, VH08XL
Supported Battery Technology
Lithium Ion
Quantity
10 (supported)
10 LED lights
Limited warranty - 1 year
5 °C
35 °C
10 - 90% (non-condensing)
55.5 cm
22.5 cm
17 cm
5 kg
Device Type: Laptop
Brand: HPE
Price Range Ex VAT: £500 - £750
