- HPE X331 - power supply - hot-plug / redundant - 165 Watt
- Power supply - hot-plug / redundant - plug-in module
- 790 g
- Input Voltage
- AC 100-240 V
- Output Voltage
- 12 V
- Power Capacity
- 165 Watt
- 8.64 cm x 23.8 cm x 4.04 cm
- Designed For
- HPE Aruba 2920-24G (165 Watt), 2920-48G (165 Watt)
- Input Voltage
- AC 100-240 V
- Output Voltage
- 12 V
- Power Capacity
- 165 Watt
- 8.64 cm
- 23.8 cm
- 4.04 cm
- 790 g
- Designed For
