StarTech.com 100W USB-C Laptop Charger
Quicklinx: JG70WS00 Mfr#: 1100LU-USB-C-CHARGER
More than 50 In Stock
£37.56 ex VAT
£45.07 inc VAT
Power and charge your laptop with this compact 100W USB-C adapter, using the built-in 1.5m cable
Powerful, Fast USB-C Charging
This USB-C power adapter delivers up to 100W of Power Delivery 3.0/2.0 power with broad voltage support (5V, 9V, 12V, 15V, 20V), letting you quickly and safely charge a wide range of devices, replacing multiple chargers with one dependable solution.
Universal Compatibility with Leading Brands
Designed for use with popular USB-C devices including Dell Pro/Plus, HP, HP ProBook, MacBook Pro, and Microsoft Surface Pro, this charger includes a 1.8m power cord and a 1.5m tethered USB-C cable for extended reach and reliable, always-ready power, ideal for mobile or hybrid work.
Safe, Reliable, and Efficient Performance
Built to keep both users and devices protected, it is ETL Safety Listed (IEC 62368-1) and CE/FCC/ICES EMC certified, with over-voltage, current, and temperature protection. Its efficient design meets DOE Level VI standards for energy efficiency.
Eco-Friendly, Plastic-Free Packaging
Packaged with sustainability in mind, the recyclable brown box minimizes environmental impact and is compact to prevent product movement or damage during transport.
StarTech - USB-C power adapter - with 1.5 m Tethered USB-C Cable - 100 watt
USB-C power adapter - external
329 g
United Kingdom
Input Voltage
AC 110-240 V
Output Voltage
5 / 9 / 12 / 15 / 20 V
Power Capacity
100 watt
Input Connectors
1 x power Type G
6.7 cm x 8.95 cm x 2.6 cm
United Kingdom
Input Voltage
AC 110-240 V
Frequency Required
50 - 60 Hz
Input Connectors
1 x power Type G
Output Voltage
Max Electric Current
5 A
Power Capacity
100 watt
Power cable - detachable - 1.8 m , USB-C cable - external - 1.5 m
Plastic housing, over current protection, over voltage protection, Power Delivery (PD) 3.0, high temperature protection, low temperature protection
TUV, EMC, FCC, RoHS, WEEE, ICES, IEC 62368-1, DoE Level VI, USB Power Delivery 3.0
25 °C
10 - 90%
6.7 cm
8.95 cm
2.6 cm
329 g
Shipping Width
16.8 cm
Shipping Depth
10.4 cm
Shipping Height
7.2 cm
Shipping Weight
500 g
