HP UPS R5500 IEC-309
Quicklinx: 4MGKWS00 Mfr#: AF416A
Does your power protection strategy need to meet the same high standards as your IT hardware? HP Rack-mountable Uninterruptable Power Systems focus on the three critical areas for uninterruptable power in dense data center environments: power density, superior battery management and serviceability. Combining unity rating with more true wattage in smaller form factors, the HP Rack-mountable UPS is highly dense. The On-line On Demand hybrid technology optimizes efficiency and heat output during general operation. All HP Rack-mountable UPSs ship with the free HP Power Protector Software that incorporates Enhanced Battery Management, an exclusive patented technology that doubles battery service life, which lowers your costs. Hot-swappable batteries and intelligent automatic bypass for continuous power improve serviceability.
  • Power Density, Battery Management and Serviceability
    HPE Three Phase On-Line On Demand Uninterruptable Power Systems provide up to 12,000 watts (W) of power in a 6-U rack form factor. This equates to 2 KW per U space, which leads the industry in power density.HPE Rack-mountable UPSs offer the ability to automatically correct for over/under voltages protecting valuable equipment.The HPE Rack-mountable Uninterruptable Power Systems incorporate Enhanced Battery Management: an exclusive, patented technology that doubles battery service life, extends battery recharge time, and provides advance notice of pending battery failure.HPE Rack-mountable Uninterruptable Power Systems Enhanced Battery Management, gives you a lower total cost of ownership by receiving the best in the industry protection for your critical equipment.HPE Rack-mountable Uninterruptable Power Systems have a uniquely designed architecture, consisting of separate, hot swappable battery and electronics modules. The built-in intelligent automatic bypass feature offers continuous power to the connected load even if the modules are being replaced.
  • Superior Battery Management
    HPE Three Phase On-Line On Demand Uninterruptable Power Systems incorporate Enhanced Battery Management: an exclusive, patented technology that doubles battery service life, extends battery recharge time, and provides advance notice of pending battery failure.HPE Rack-mountable Uninterruptable Power Systems Enhanced Battery Management, gives you a lower total cost of ownership by receiving the best in the industry protection for your critical equipment.Industry-leading three-year warranty also covers batteries.
  • Serviceability
    HPE Three Phase On-Line On Demand Uninterruptable Power Systems have a unique architecture, consisting of separate, hot swappable battery and electronics modules. The built-in, intelligent automatic bypass feature offers continuous power to the connected load even if the modules are being replaced.HPE Rack-mountable Uninterruptable Power Systems offer faster time to repair (low MTTR), automatic and manual bypass and increased flexibility through modular design.
  • You're Covered
    HPE Three Phase On-Line On Demand Uninterruptable Power Systems include industry-leading three-year warranty also covers batteries.Integrated HPE Server and Support Care Pack coverage of HPE UPSs up to 12 kVA, eliminating the need for costly extended warranties.Guaranteed to work with all Hewlett Packard Enterprise server, storage, and networking equipment.
HPE UPS R5500 - UPS - 6000 VA
UPS - rack-mountable
Rack Size
3U
73 kg
Input Voltage
AC 220/230/240 V
Output Voltage
+ 6% / - 10%
Power Capacity
6000 VA
Input Connectors
1 x power IEC 60309 32A
Output connectors
4 x power IEC 60320 C19 , 4 x power IEC 60320 C13 , 1 x power IEC 60309 32A
Lead Acid expandable
Run Time (Up To)
5 min at full load
44.5 cm x 66 cm x 13 cm
3-year warranty
ProLiant BL20p G3, BL20p G4, DL120 G6, DL320 G4, DL320 G5p, DL320 G6, DL360 G4p, DL360 G5, DL360 G6, DL360 G7, DL365, DL365 G5, DL370 G6, DL380 G7, DL385, DL385 G5, DL385 G7, DL580 G7, DL585 G6, DL585 G7, DL785 G5, DL785 G6, DL980 G7, ML330 G6, ML350 G5, ML350 G6, ML370 G5, ML370 G6, ML570 G4
Height (Rack Units)
3U
Input Voltage
AC 220/230/240 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
+ 6% / - 10%
Power Capacity
6000 VA
Output Waveform
Sinewave
Expandable
Lead Acid
Run Time (Up To)
5 min at full load
Recharge Time
24 hours
1 x management (RS-232) - 9 pin D-Sub (DB-9)
Serial cable - external , Power cable 3 m
Rack Mounting Kit
Included
Equipment Protection Value
250000 US Dollars
FCC Class A certified, C-Tick, BSMI, GOST, GS, UL 1778, EN 50091-2, IEC 62040-1-1, CSA C22.2, EN 50091-1, FCC CFR47 Part 15, UL 60950-1, EN 60950-1
Software Included
Drivers & Utilities
Limited warranty - parts and labour - 3 years
10 °C
20 - 80%
Sound Emission
46 dB
44.5 cm
66 cm
13 cm
73 kg
Shipping Width
81.3 cm
Shipping Depth
97.8 cm
Shipping Height
35.6 cm
Shipping Weight
91 kg
HPE ProLiant BL20p G3, BL20p G4, DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL320 G4, DL320 G5p, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G4p, DL360 G5, DL360 G5 Base, DL360 G5 Entry, DL360 G5 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL365 Base, DL365 Entry, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL365 Performance, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380 G4, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385, DL385 G5 Entry, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G6, DL585 G6 Base, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance, DL980 G7, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, ML570 G4, ML570 G4 High Performance
