HP ProCurve Switch 2600-8 PWR
Quicklinx: 4GWGWS00 Mfr#: J8762A
The ProCurve Switch 2600 series is a collection of low-cost, stackable, multi-layer, managed switches with 48, 24, or 8 auto-sensing 10/100 ports and dual-personality ports for 10/100/1000 or mini-GBIC connectivity. The ProCurve Switch 2650-PWR, 2626-PWR, and 2600-8-PWR are IEEE 802.3af-compliant for Power over Ethernet and provide up to 15.4 W per port. A redundant external power supply is also available as an accessory.
  • Connectivity
    Dual-personality functionality: two 10/100/1000 ports or mini-GBIC slots for optional fiber connectivity such as Gigabit-SX, -LX, or -LH.Power over Ethernet (IEEE 802.3af) compliant (HPE ProCurve 2650-PWR, ProCurve 2626-PWR, ProCurve 2600-8-PWR): provides up to 15.4 W per port to power IP phones, wireless access points, Web cameras, and more (HPE ProCurve 2650-PWR may require an external power supply to provide full 15.4 W for all 48 PoE-ready ports).
  • Performance
    13.6 Gbps (ProCurve 2650 and 2650-PWR)/9.6 Gbps (ProCurve 2626, 2626-PWR, 2600-8-PWR) backplane: wire-speed non-blocking architecture for low-latency throughput.
  • Resiliency and high availability
    IEEE 802.3ad Link Aggregation Control Protocol (LACP) and ProCurve trunking: support up to 6 trunks, each with up to 4 links (ports) per trunk; trunking across modules is supported.Spanning Tree Protocol (IEEE 802.1D): provides redundant links while preventing network loops.IEEE 802.1w Rapid Convergence Spanning Tree Protocol: increases network uptime through faster recovery from failed links.IEEE 802.1s Multiple Spanning Tree: provides high link availability in multiple VLAN environments by allowing multiple spanning trees.Optional external redundant power supply (ProCurve 2650-PWR, ProCurve 2626-PWR, ProCurve 2600-8-PWR): provides uninterrupted power; sold as an accessory.
  • Manageability
    VLAN support and tagging: support complete IEEE 802.1Q (4,096 VLAN IDs) and 253 VLANs simultaneously.GARP VLAN Registration Protocol: allows automatic learning and dynamic assignment of VLANs.
HPE Switch 2600-8-PWR - switch - 8 ports - Managed
Switch - 8 ports - Managed - stackable
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE) + 1 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP
Flow control, auto-sensing per device, BOOTP support, trunking, VLAN support, manageable
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44.3 cm x 22.5 cm x 4.4 cm
3.4 kg
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
PoE
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), TACACS+, Secure Shell v.2 (SSH2)
1 x Motorola MPC8245: 266 MHz
RAM
32 MB SDRAM
Flash Memory
8 MB
8 x 10Base-T/100Base-TX - RJ-45 PoE , 1 x serial (RS-232) DB-9 , 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x SFP (mini-GBIC)
Internal power supply
190 Watt
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, CISPR 24, cUL, EN 60950, EN 61000-3-2, EN55022, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, NOM, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, CSA 22.2 No. 950, UL 60950, UL 1950 Third Edition
44.3 cm
22.5 cm
4.4 cm
3.4 kg
50 °C
15 - 95%
