The HP Ultra Extended Life battery allow you to work longer indipendently from a power plug. The Ultra Extended Life battery provides the convenience of charging with an AC adapter plugged into the built-in Integrated AC Power Port when it is not in use. With the improved battery life, the battery is a great solution for anyone who requires maximum battery life for all-day computing.
- HP BB09 - laptop battery - Li-Ion - 8850 mAh
- Laptop battery
- 682 g
- Battery
- Ultra extended life - Lithium Ion 9-cell - 8850 mAh
- 15 cm x 29 cm x 3 cm
- 1-year warranty
- Designed For
- EliteBook 8460p, 8460w, 8470p, 8470w, 8560p, 8560w, 8570p, 8570w, 8760w, 8770w; Mobile Thin Client 6360t; ProBook 6360b, 6460b, 6465b, 6470b, 6475b, 6560b, 6565b, 6570b; ZBook 15, 17
- Laptop battery
- Technology
- 9-cell Lithium Ion
- Voltage Provided
- 11.25 V
- Capacity
- 8850 mAh
- Recharge Time
- 3.5 hours
- Limited warranty - 1 year
- 0 °C
- 45 °C
- 15 cm
- 29 cm
- 3 cm
- 682 g
- Shipping Width
- 49 cm
- Shipping Depth
- 19.3 cm
- Shipping Height
- 4.5 cm
- Designed For
- HP EliteBook 8460p Notebook, 8460w Mobile Workstation, 8470p Notebook, 8470w Mobile Workstation, 8560p Notebook, 8560w Mobile Workstation, 8570p Notebook, 8570w Mobile Workstation, 8760w Mobile Workstation, 8770w Mobile Workstation , HP Mobile Thin Client 6360t , HP ProBook 6360b, 6460b, 6465b, 6470b, 6475b, 6560b, 6565b, 6570b , HP ZBook 15 Mobile Workstation, 17 Mobile Workstation
